Intake manifold Water fitting question
Old Dec 9, 2007 | 10:00 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Intake manifold Water fitting question
Well, since I have decided not to run coolant through the throttle body.
I'm looknig at this and rather than splice the hose, I'm figuring I'll just run an entirely new one. Hose is cheap enough.
Anyway, I need a right angle barb fitting that has 3/4 inch threads.
This would make running the hose much neater.
Summit wants $40 for a hose barb fitting.
That, is rediculous.
ANyone have any suggestions?
Old Dec 9, 2007 | 10:15 PM
Aardwolf's Avatar
Aardwolf
I thought of using one but did not, it would route the hose in tight places by the fuel lines. I ran new hose and it does arc around under the TB but looks fine.
Old Dec 9, 2007 | 10:18 PM
jsup's Avatar
jsup
Possible pic? Does it interfere with the pulley system? I'd love to pull it straight under the AC compressor rather than over the valve cover.
JackDidley's Avatar
JackDidley
The guy at the Carquest let me go in the back and find a formed hose to hook to the straight fitting. Maybe you can do the same.
Old Dec 9, 2007 | 10:38 PM
_twisted_'s Avatar
_twisted_
they have L shaped hose at napa in 5/8" and 3/4" might even have 1/2"
Old Dec 9, 2007 | 10:41 PM
jsup's Avatar
jsup
But then I'd have to have another connection in the system. Another opportunity to leak.
Does it stick out far? Will it interfere with anything else in the motor?
Maybe I can do that and put in a flush kit at that point...Looks kinda stupid though.....
Old Dec 9, 2007 | 10:44 PM
_twisted_'s Avatar
_twisted_
its not another connection, it is trim able its like 8" x 3' perfect for coming out of the intake to the heater line
Old Dec 9, 2007 | 11:01 PM
Dads90's Avatar
Dads90
Take a look at mine. The hose is tie wrapped to the AC hose to keep it off the frisby.
Old Dec 10, 2007 | 03:44 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Mine is the same way, works fine, you don't want to route it under the A/C, makes it hard to avoid the belts, and you would have to remove the compresior to replace the hose.
Old Dec 10, 2007 | 07:22 AM
mseven's Avatar
mseven
I don't have any of those problems...
Not the best pics. but do you mean like this:
from the first build:
The 90* has pipe thread on one side and the other has std. It is connected it to a straight/barbed one side, swivel nut other so that the hose can come off more easily w/the 90 in place. I also cut a hole in the inside area of the AC bracket for better routing. Fittings can be purchased from Earls' or Aeroquip makes 90's, and barbed straights etc.
Old Dec 10, 2007 | 08:51 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I tweaked the angle of the metal tube to lay it down a bit, then routed new hose under ac compressor and onto straight nipple on intake. You can see the hose here, it has a little arc to it before it hides under AC compressor.
I didn't like to see nipples with no use, so I eliminated them.
To Intake manifold Water fitting question
