Start engine with no tranny attached?
Old Dec 11, 2007 | 09:23 AM
LD85's Avatar
LD85
Default Start engine with no tranny attached?
I am trying to find a vibration in the engine and struggling, the vibration only happens from 3000 rpm and up. Vibration happens with car in neutral, clutch engaged or disengaged.
Bought new plug wires, plugs, distributor cap and rotor
I have checked the Ohm's on the injectors, OK
Fuel Pump pressure is good throughout the rev range.
No bent valves per the leak test at 50-psi
Roller Lifters appear to be solid
Distributor gear is good, not worn
Clutch disc, PP and FW checked OK
So can I start engine with no tranny attached to check for the vibration without the tranny?
Old Dec 11, 2007 | 10:46 AM
Slalom4me's Avatar
Slalom4me
Internally ballanced still, right?
As long as it is supported, my vote is there will be no issues.
Old Dec 11, 2007 | 11:02 AM
LD85's Avatar
LD85
I didnt think so,,,,,,,,,,,External balance, I planned on leaving the FW and Clutch on.
Old Dec 11, 2007 | 11:03 AM
StealthLT4's Avatar
StealthLT4
aww...I was hoping you'd give us a video of what not to do
Old Dec 11, 2007 | 11:12 AM
Slalom4me's Avatar
Slalom4me
I must be thinking of someone else here with a 406 that IIRC, he built as
IB. Anyway, here are some other examples showing operation with PP
and w/ FW & C.
I keep expecting this guy to say 'it's got cop tires, cop suspension,
cop shocks ...'
Here is an SBC with PP, C & bell housing
Old Dec 11, 2007 | 11:18 AM
Slalom4me's Avatar
Slalom4me
Ok, don't do this:
Old Dec 11, 2007 | 11:46 AM
CFI-EFI's Avatar
CFI-EFI
It doesn't matter how it is balanced. With the flywheel on and properly secured, the presents of the transmission makes no difference. Have at it.
RACE ON!!!
Old Dec 11, 2007 | 12:00 PM
Slalom4me's Avatar
Slalom4me
I agree.
I started off on the Internal/External balance discussion because I
failed to fully read LD85's post and had it in my head that he wanted
to isolate operation solely to the engine's rotating assembly by
excluding the transmission AND flywheel & ect.
Add this contretemps to my Oops count.
Old Dec 11, 2007 | 12:17 PM
jhammons01's Avatar
jhammons01
RACE ON!!!
Aha!!! A mistake!!
I picture a Transmission bearing wrapped gifts.....
I think you meant "presence".....just a little fun on a Tuesday morning.
OP whether or not you get to open a gift....CFI is right(as usual)
Old Dec 11, 2007 | 01:05 PM
l1sikes's Avatar
l1sikes
Running it w/o transmission is not a problem. Just don't waste your time trying to push start it.
Old Dec 11, 2007 | 02:37 PM
l88rocket's Avatar
l88rocket
I have done it with the motor in the car and no tranny, just support the rear of the engine with a floor jack, and fire it up, becareful because with out the tranny it will rap very fast unloaded
Old Dec 11, 2007 | 02:48 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default run engines
run the engine, but look at the accessories, alternator, air cond, pulleys, etc. usually you are feeling the harmonics of the serpentine belt
system.
I would first start it cold without the serpentine belt for a few seconds rather than pull the trans. No longer than 60 seconds.
If you still have the vibration, shut it off, put the belt back on, and note the difference and let the engine cool off or warm up.
Then if you want to go the other route and take off the trans, then go for it. You will probably want to inspect the harmonic balancer really good before you take the trans out.
Sometimes the balancer is the culprit as well as an out of round pulley or accessory.
Old Dec 11, 2007 | 02:52 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by jhammons01
Aha!!! A mistake!!
GUILTY as charged! I kept looking at that before I pushed the "Submit Reply" button. If you say it fast enough, it sounds OK, but I admit, it sure looks funny. Maybe I'm human, after all.
RACE ON!!!
Old Dec 11, 2007 | 05:23 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Curious to hear your results I have a weird slight vibration at ~3.5-4k. It isn't bad and goes away after that point. It definitely isn't bad enough to be an out of balance motor (ext balanced) I'm thinking it is the dampner. But I'll have to try that serp belt test and I'm very interested to hear your results.
Good luck!
Old Dec 11, 2007 | 05:45 PM
TIMSPEED's Avatar
TIMSPEED
I'm sure you've already checked this...
but on my 85 many moons ago, I had the stock balancer come apart, and everything was fine, but it would have an odd vibration in the mid-range rpm's...so, just something to think about...
Old Dec 11, 2007 | 10:43 PM
fnsblum's Avatar
fnsblum
"Sometimes the balancer is the culprit". Chris, could you explain this? Are these still two piece with a rubber insert. I am chasing a vibration also. Thanks. Later! Frank
Old Dec 12, 2007 | 01:11 AM
MrRenoman's Avatar
MrRenoman
This is hilarious...
Ok, don't do this:
To Start engine with no tranny attached?
Old Dec 12, 2007 | 10:18 AM
rick lambert's Avatar
rick lambert
That video is funny. Hey, I agree about checking the balancer first, actually lost one racing a mustang once...I was lucky.
Old Dec 12, 2007 | 10:26 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
If you leave the clutch attached and the transmission input shaft isn't there, what are you going to use to center the disk?
Old Dec 12, 2007 | 10:45 AM
CFI-EFI's Avatar
CFI-EFI
The same clamping force of the pressure plate assembly that drives the clutch disk (and the car) when it does have the transmission input shaft sticking through it. Centering would only be an issue if, when, the clutch were disengaged.
RACE ON!!!
