Cam Install
Dec 11, 2007 | 01:52 PM
Cam Install
Does The Motor Have To Come Out For The Cam Intall. I Will Be Pulling The Rad Is There Enough Room To Get That Beast In There.
Dec 11, 2007 | 03:22 PM
From: One day you're a Comet...the next day you're dust... Arkansas
Dec 11, 2007 | 03:29 PM
No, the engine don't need to come out, just the radiator and air conditioner condenser
Randy
Dec 11, 2007 | 04:54 PM
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
You have to loosen at least motor mount and jack up the motor about 1 inch.
Dec 11, 2007 | 05:05 PM
Quote:
Originally Posted by
jsup
but only necessary if you have a 'vert or Z51 or Z52 coupe. Those have a bigger "wonderbar" crossmember. Otherwise, it should clear without lifting the motor at all.
Dec 11, 2007 | 05:16 PM
No, just everything in front of the motor, but you might have to raise it a bit.
Dec 11, 2007 | 05:28 PM
Dec 11, 2007 | 06:51 PM
On my 87, no motor lifting needed. The AC condensor can stay hooked up, just move it forward a bit.
Dec 11, 2007 | 10:06 PM
There is not enough room to remove/replace the cam in my 85. But, there is enough "slack" in the AC hoses to roll the condenser out of the way. Then you got gobs and gobs of room.
Dec 13, 2007 | 08:38 AM
rlane5
Randy
On my 89, I had to lift the motor about 1". It is doable, but next time I will pull the motor and make it much easier.
Vic
Dec 13, 2007 | 08:52 AM
Hi Vic I was looking at your numbers in the quarter.is this with a stock 350?What horse power numbers are you running?Thanks,Steve
Dec 13, 2007 | 11:24 AM
What about on a 95 vert? I've already had the radiator in and out. I'm more concerned about the condensor. Can the AC condensor just be moved aside to install a cam or does it need to be disconnected?
Dec 13, 2007 | 12:26 PM
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
I haven't looked at it yet. but does the oil pan on an LT1 need to be dropped like on the earlier small blocks?
