Belt tensioner question
Old Nov 24, 2001 | 04:20 PM
Fla96LT4's Avatar
Fla96LT4
Default Belt tensioner question
I have a noisy pulley on the belt tensioner (87). Looks like one 15mm bolt holds the spring assembly to the bracket. Any surprises if I remove this bolt? Springs "flying" or other issues. It looks too easy............and most things I try to fix are not! :D
Old Nov 24, 2001 | 04:36 PM
JonM's Avatar
JonM
Default Re: Belt tensioner question (Fla87)
Nope...comes right off. Once you get the pully off, take the three nuts and bolts off that hold the two halfs togther. Then tap a screwdriver between the halfs to seperate. Then you can take the bearing out and go to your local bearing distributor and get a replacment. Shouldn't be any more then a few bucks.
Old Nov 24, 2001 | 05:56 PM
Fla96LT4's Avatar
Fla96LT4
Default Re: Belt tensioner question (JonM)
Thanks JonM............looking forward to an "easy" fix for a change. Just finished R&R of differential and it was a serious pain!
To Belt tensioner question
