Had codes pulled today...help?
Old Dec 12, 2007 | 11:25 PM
StealthLT4's Avatar
StealthLT4
Default Had codes pulled today...help?
Just had the PCM codes pulled from my '96 (no EMC or ABS codes, I checked those myself), and here are the problems:
-High idle
-Bank 2 o2 sensor running lean ::: FIXED, I think
-Not a code, but the reverse lights don't work ::: FIXED
So, what all should I do? The previous owner said he cleaned the IAC valve, and it worked for a couple of weeks before the light came on again, so that's not the culprit (at least cleanliness isnt....). I was thinking I should clean the TPS and maybe take a look at the TB to make sure it isnt gunked up, then cleaning the IAC valve again. If that doesn't work, I may have to replace the IAC valve? I'm not really sure.
The o2 sensor: The car has EM headers, random-tech cats and Corsa exhaust; I've heard stories of high-flow systems causing o2 sensor malfunctions due to them not reaching operating temperature. Do you think this is the case, and I should get o2 simulators? Or is it simply a bad o2 sensor...
Lastly, the reverse lights don't work. I checked the fuse, it's OK. I was planning on replacing the bulbs before I replace the reverse switch ($74, ugh), but is there anything else I should check?
Thanks!
Old Dec 13, 2007 | 10:22 AM
StealthLT4's Avatar
StealthLT4
anyone...?
Old Dec 13, 2007 | 11:14 AM
CFI-EFI's Avatar
CFI-EFI
For the code(s) the best course of action is to follow the trouble shooting charts in your FSM for whatever codes are displayed. The TPS is external to the TB and not likely to need cleaning, but it can't hurt to look it over. It is possible for the IAC to get gunked up, again, quickley depending on conditions. If the IAC is gunked up, or if it wasn't done at the last IAC cleaning, the IAC passages in the TB should definitely be cleaned. If you are having problems staying in closed loop then heated O2s are likely the cure.
The high idle isn't likely caused by whatever set the code for the O2. Along with the IAC maintenance, check very closely for vacuum leaks.
For the back up lamps, the trouble shooting is pretty basic. Is there power to them when there should be? Are the bulbs burned out? Don't replace the back up light switch with out first testing it.
RACE ON!!!
Old Dec 13, 2007 | 12:25 PM
StealthLT4's Avatar
StealthLT4
Thanks! I have the FSM, but I couldn't find much of any help as far as diagnosing problems. It sure will help figuring out how to take some of this stuff off though.
The Vette's getting a state inspection right now, but I'm gonna start testing stuff as soon as I get it back. I'm sure I'll post again if I run into any problems.
Old Dec 13, 2007 | 12:38 PM
LouisvilleLT4's Avatar
LouisvilleLT4
Seriously? Practically the whole FSM is big flow charts of diagnostic procedures... There are ones for the codes your car threw, there is one for the backup lights, there is one for almost everything. Even if you have that goddawful half-complete "preliminary" manual.
Old Dec 13, 2007 | 01:32 PM
AssocRacer's Avatar
AssocRacer
First, and this is just a thought as i may be way off base, but the o2 sensor may be causing the high idle. Second, you say the state has your car for an inspection. I keep seeing that here, why is that? I've never heard of the state of Wisconsin taking a car for inspection unless they were inspecting it to give it a new title from a salvage title.
Old Dec 13, 2007 | 01:46 PM
StealthLT4's Avatar
StealthLT4
In VA we have to have it inspected yearly. It's just a safety thing. Make sure all the lights work, no holes in the exhaust, no holes in the floor...stuff like that. I just got it back; I'm actually surprised it passed with no reverse lights, but I'm not complaining..
Old Dec 13, 2007 | 02:03 PM
LouisvilleLT4
Statewide inspections for road safety as opposed to emissions? Now that is something I can get behind
Old Dec 13, 2007 | 05:03 PM
StealthLT4's Avatar
StealthLT4
OK, did some more work on it. Cleaned the o2 sensor (REALLY dirty, black gunk), as well as the IAC valve and the TB (what I could clean without taking it off). Disconnected the battery for 30 min to reset the PCM.
Result: Initially, it idled well and the exhaust smelled right (not rich). Let it sit for a few minutes idling perfectly, then drove it around to get up to operating temperature. Almost immediately, the idle went back to the ~1100rpm idle it has been at. After about 15 minutes, the Service Soon light came back on. I haven't scanned it yet, but I'm betting it will be the high-idle code. Any more ideas on this high idle situation?
Old Dec 13, 2007 | 05:46 PM
LouisvilleLT4
Yes: Look in your FSM at the recommended diagnostics for that code. Stop trying random quick-fixes, and do the proper test procedure. Come back once you have either done that or gotten stuck on a step.
Old Dec 13, 2007 | 06:21 PM
RRT vette's Avatar
RRT vette
First. You will want to fix the O2 sensor code. The 96 stock O2 sensors should be heated (3 or 4 wire). To follow the FSM and fix the code you will need a real time scanner. If you don't have a scanner, which I assume you don't if someone pulled the codes for you, then you might get lucky by replacing the O2 sensor in question (not cheap though). No amount of cleaning will work with O2 sensors. They are delicate to any type of solvents, ect. Also check the wiring and connection to the O2 sensor and make sure the wires have not grounded on the exhaust or cat if you have them. After the code is gone, see if the high idle is still there. You will want to make the stored code disapear before starting on the idle situation. O2 sims will most likely benefit you on the post cat sensors.
For the backup lights, just follow CFI's advise. Make sure your getting voltage to them when the tranny is in reverse. Place blocks behind the wheels and pull the e-brake if you don't have help. If you get voltage at the light plug, replace the bulbs.
Old Dec 13, 2007 | 06:33 PM
CFI-EFI's Avatar
CFI-EFI
We have annual safety and smog tests. I think some of the newer cars are smogged biannually until they reach a certain age.
It's all in there.
RACE ON!!!
Old Dec 13, 2007 | 10:49 PM
LouisvilleLT4
Or just turn the ignition to "on" without starting the engine and put the transmission in reverse.
Old Dec 13, 2007 | 11:24 PM
StealthLT4's Avatar
StealthLT4
I'm working my way through the FSM...some of that stuff is kind of over my head though. I'm doing what I can.
Just bought a multimeter tonight, so will begin working on the reverse lights now.
It's a manual, so yeah, I'm not gonna start the car and chock the wheels in reverse
Old Dec 14, 2007 | 08:24 AM
LouisvilleLT4
So as not to break your car or the multimeter, make sure you use the multimeter right...don't check continuity (resistance) in a circuit unless all the wires are powered down and off. Don't check amperage between "hot" and "ground." Don't use AC mode to measure DC or vice versa. Try to always use the red probe on the side with the higher voltage (in other words, properly observe polarity). When you're done measuring large amperages with the "unfused" slot, make sure you switch it back over and don't try to take other measurements with that slot.
If you want to read the amperage that circuit is using, you can pull the fuse associated with it (diagrams of all fuse wiring are in the beginning of the electrical section), switch your multimeter to DC amperage using the "unfused" slot, and use the probes where the fuse goes. To measure voltage, remove the light and measure between the hot and ground wiring terminals (but don't try to measure amperage there, as explained above).
Old Dec 14, 2007 | 07:26 PM
StealthLT4's Avatar
StealthLT4
Thanks for the tips. I've been playing with multimeters this whole semester in my Electrical Engineering class, so I'm almost sick of using them... I splurged and got a nice Craftsman auto-scaling multimeter though, so its pretty painless.
I got the reverse lights working...apparently it was just a loose wire somewhere, because they worked when I put everything back together. Thank GOD I don't have to buy a new switch...
I cleaned the o2 sensor with TB-cleaner, and the code hasn't come back, but I read somewhere that they don't work properly when cleaned, and they have to be replaced. Is this true? I want to make sure this is fixed before I continue chasing the idle problem, as it could be contributing.
Also, I can't find the IAC valve on gmpartsdirect.com. It has to be on there, I just can't find it. Has anyone?
Old Dec 14, 2007 | 07:50 PM
RRT vette's Avatar
RRT vette
Unleaded fuel is essential to the proper and continued operation of the O2 sensor. Never use cleaning solvents of any kind on the O2 sensor, solvents can permanently contaminate the sensor element. If the sensor has over or around 50K miles on it..replace it as they get sluggish with age.
If your not looking to purchase just a GM IAC, Autozone or most any other auto parts stores carry them for around $35. As stated, resolve the code and go from there.
To Had codes pulled today...help?
Old Dec 14, 2007 | 07:56 PM
CFI-EFI's Avatar
CFI-EFI
What is over your head? Maybe we can be of help. Skipping steps by "I'm doing what I can" is close to worthless. The diagnostic steps build on one another. There are in a logical sequence. Maybe this work isn't for you.
It is correct that an O2 doesn't respond well to cleaning, but have any of your tests and trouble shooting proved the O2 sensor is bad? It is possible you have ruined a good O2 sensor by "fixing it".
RACE ON!!!
Old Dec 14, 2007 | 08:06 PM
StealthLT4's Avatar
StealthLT4
Well, doing a fuel injector balance test is out of my league, at least without sending them to a shop. That was I think the second item on the diagnostic list.
When I had the car scanned (I have a scanner now though ), one of the codes was for the bank 2 o2 sensor. When I took it out, it was pretty caked in sut. Also, you could tell the car was running rich just by the smell. Performance-wise, it still felt/feels good.
I'll get a new o2 sensor. Then see if that has any effect on the idle.
The thing about the ide is; if it were injectors, or a vacuum leak, it would also cause problems across the RPM band, correct? The only problem is that it idles at 1100rpm instead of ~800. There's a small amount of searching, but no more than 100rpm or so.
Also, before I come to a stop, it will idle around 1600-1900rpm (ex: pushing the clutch in to drift down a hill). And if I give it a little bit of gas while its idling at 1100, it will settle down to 900-1000 for a while before returning to 1100rpm.
Old Dec 14, 2007 | 09:02 PM
CFI-EFI's Avatar
CFI-EFI
A code only identifies the circuit a bad, out of parameter, reading came in on. If the mixture is out of kilter a code could be set because the O2 correctly read a mixture that shouldn't exist and that the O2 didn't cause. You need to trouble shoot each code, each time, to isolate and cure the CAUSE of the problem. Once the culprit is located, it needs to be tested to ensure it really is bad. Otherwise you can waste a lot of money replacing good parts. Like I keep preaching, don't shoot the messenger.
No. Not necessarily.
The idle problem isn't likely to be injectors. The O2 code very likely may be.
That may be caused by a vacuum leak or even a warn, sticking, TB. Step one is to fix the cause of the codes. Then, you should find additional trouble shooting charts in your FSM that addresses the drive-ability problems, like your high idle.
RACE ON!!!
