service engine soon "94"
Old Dec 13, 2007 | 04:24 PM
llesg's Avatar
llesg
Default service engine soon "94"
What does it mean when this light comes on? It has been making a periotic apearance every now and then.
And can anyone tell me how to search,I'm sure someone else has asked this question some time, but I can't seem to figure it out!!!
I did a search but nothing related came up !!! Thank's ,Rick
Old Dec 14, 2007 | 12:06 AM
Red Dwarf's Avatar
Red Dwarf
Read the info in this site thoroughly. It will give you the necessary info
to diagnose your problem.
If there's something you don't understand, post it & someone will help you out.
http://www.corvettephotographs.com/c4vettes/index.htm
Old Dec 14, 2007 | 12:19 AM
StealthLT4's Avatar
StealthLT4
thats' the "Check Engine Light" as many other cars call it. It means your CCM has thrown a code, and you need to find out what's wrong. HERE is a forum thread detailing how to use your own car's diagnostic mode to find the code. Hope all ends well!
Old Dec 26, 2007 | 03:57 PM
kenmack's Avatar
kenmack
Default Service engine soon
I'll share my experience with "service engine soon"
Bought my 87 in mar of 94, 22,000 mi.Driving home from purchase SES light came on. Car runs great! Never did throw a code!!!!!Changed the ECM (electronic control module)still no fix.Long story short 13 years later SES still blinks on about 40% of the time,someone said there are 2 relays from ECM to dash and they could be faulty.Sold the car with a full explanation of light and 5 attempted diagnostics with no code evident.Pretty flakey electronics I'd say??!!
Old Dec 26, 2007 | 07:07 PM
Harryscarlot's Avatar
Harryscarlot
sent you a PM
Old Dec 26, 2007 | 09:01 PM
pcolt94's Avatar
pcolt94
Default Just a slight correction
The "service engine soon" light (MIL, malfunction indicator lamp) is driven by the PCM and is a indication that it has a code present in it. The CCM codes are indicated by the lower portion of the speedometer indicator where the info is displayed. The CCM basically monitors the chassis and rest of car systems (but not brake systems) .
The PCM is module 4. This will be displayed when pins 4 & 12 are connected together which will put it in the diagnostic mode. Once in the diagnostic mode, you can use this website for code identification. This is only for module 4, the PCM (power control module), which is for engine and transmission codes.
http://www.corvettedoctor.com/1994_96_DTC_Codes.html
Any other step by step info can be obtained on the Forum, or just ask.
To service engine soon "94"
