ZF clutch fork pivot ball help
Old Dec 15, 2007 | 11:46 AM
corvette90's Avatar
corvette90
Default ZF clutch fork pivot ball help
hi all
wanted to change the clutch today on my friends 91, everything went smooth, until i got to the bellhousing and the clutch fork pivot ball...
anyways, i wasnt able to get it out, i had to cut off the pivot ball in the bellhousing for removing it..
can you give me a part number for this ?
i have the capabilities in the company im working for, to have it made of tool steel...should i go this route?
thank you
Old Dec 15, 2007 | 02:43 PM
BAM92's Avatar
BAM92
It uses a 12mm allen to remove it and it is a reverse thread. But I guess this is useless now if you cut it in half already.
Old Dec 15, 2007 | 02:51 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Old Dec 15, 2007 | 03:27 PM
Jeffvette's Avatar
Jeffvette
should be #10227809
Old Dec 15, 2007 | 06:00 PM
corvette90's Avatar
corvette90
Hi
i have done this on my vette before, so i know that this bolt is clockwise to remove...problem was, that the bolt that tight, so the allen cracked the bolt...no chance to remove...
Old Dec 15, 2007 | 06:01 PM
corvette90's Avatar
corvette90
Originally Posted by Jeffvette
should be #10227809
thank you very much!!
PS: do you know a place where to get it?
Old Dec 15, 2007 | 07:04 PM
Jeffvette's Avatar
Jeffvette
Part has been discontinued.
I can get a new one for around 50 bucks.
To ZF clutch fork pivot ball help
