Auxillary Fuse Block
Old Dec 16, 2007 | 01:58 PM
1irishprince's Avatar
1irishprince
Default Auxillary Fuse Block
I have an '86 coupe & have done some searching in my FSM and on the forum, but cant seem to find what those three fuses behind the info center are for. They are next to the hazard flasher and one of the fuses is blown...someone really did a chop job before I got the car when trying to wire in an aftermarket cd player. There is writing under each fuse, but is worn mostly off and is not legible anymore.
Old Dec 16, 2007 | 03:07 PM
bogus's Avatar
bogus
Pull each fuse and find which is blown.
the FSM will tell you which fuse does what.
Old Dec 16, 2007 | 03:16 PM
1irishprince
Well, I have half the dash taken apart trying to find out why my cluster keeps flickering off and on...I am sure it's a loose wire or something...but in the process, I figured I would disconect the major componants so I would be able to see all the wiring when I happened upon the aux fuse block...have miles of wiring diagrams to go through...just thought someone would know what they went to.....just a small block with 3 mini fuses...a 3a, 10a, and a 5a fuse...the ten amp fuse is in the middle and is blown(who knows if it's even the correct amp fuse)
To Auxillary Fuse Block
