Would this kit work?
Old Dec 16, 2007 | 11:52 PM
lil_Mike's Avatar
lil_Mike
Default Would this kit work?
ok well i got a 84 with crossfire. i pretty much rebuilt the top end of the motor and was thinking of trying a nitrous kit. i knwo it can be done because ive been talkin to jrwood who is tryin to sell his 84 that has a kit on it. his is a NOS kit that is discontinued but i found a kit from nitrous direct that looks like it will work.
so what do you guys think?
(sorry for stealing your pic jrwood its the only one i can find)
heres the setup he had
heres a kit that nitrous direct has
http://www.nitrousdirect.com/corvett...rous-kits.html
Old Dec 17, 2007 | 12:47 AM
tjwong's Avatar
tjwong
It probably would work, but I am willing to bet that the kit shown is for a later model Corvette with port fuel injection. What this means is that the fuel jets are sized based on a high pressure 55 PSI fuel system that is for the new LSx engines. If you purchase that system you will need to call the manufacturer up and get larger fuel jets that is properly sized for the low (12 PSI) pressure TBI system that you have. If you attempt to use the kit as is, you may lean the engine out and cause a major failure of internal components such as frying pistons.
Old Dec 18, 2007 | 07:06 PM
BAM92's Avatar
BAM92
His kit was NOS #5125. I think he said they don't make it anymore.
To Would this kit work?
