where's EFI.CFI.
Old Dec 17, 2007 | 08:56 PM
staugur's Avatar
staugur
Default where's EFI.CFI.
See my post under "Brains needed"
Old Dec 17, 2007 | 09:42 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by staugur
where's EFI.CFI.
Rat cheer!
I just looked at that thread and I would say you have had some very good suggestions to check out. Check the fuel pressure, especially under load. Reduce your plug gap to something close to normal. You might try .035" to .040". You could install an oscilloscope to check the secondary ignition, but to be meaningful you would have to have a way to load the engine; either a dyno or a test drive. A broken valve spring isn't always that easy to spot. It doesn't have to fly apart and scatter all through the engine to be a problem. There are, on the car, valve spring testers. Follow through on all the good advice you have already received. Unfortunately, I have no "silver bullet" to offer.
RACE ON!!!
Old Dec 18, 2007 | 01:29 PM
dan0617's Avatar
dan0617
Look at that, just like the phone book last name first..EFI,CFI
Bueller......Bueller....Bueller....
Old Dec 18, 2007 | 06:16 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've called him. It was definitely listed under E in the phone book.
Old Dec 18, 2007 | 06:54 PM
CFI-EFI's Avatar
CFI-EFI
I'm not even going to ask...
I am hoping everyone has noticed my restraint in not dealing with the title to the parent thread. Every time I saw that I almost gave in to temptation.
RACE ON!!!
Old Dec 18, 2007 | 10:30 PM
dan0617's Avatar
dan0617
Yeah, I hear ya. Someone is needing brains and paging you. I guess scraping the bottom of the barrel is an understatement!! Had to get that one in CFI, gotta use every opportunity that blows my way.
Old Dec 19, 2007 | 12:56 AM
Sam Lam's Avatar
Sam Lam
I noticed your restraint and congargultions for not "giving in" to temptation
Old Dec 19, 2007 | 01:25 AM
staugur's Avatar
staugur
Don't even want to intrude on this one.I'll just leave you to play with each other.Did fix my problem 'tho.
To where's EFI.CFI.
