Holley stealth ram
Old Dec 18, 2007 | 01:46 PM
lumij3's Avatar
lumij3
Default Holley stealth ram
I am about to install a stealth ram in my 88 corvette. does anyone has tips or concerns I should be aware of when and how to do this? Thanks
LJ
Old Dec 18, 2007 | 02:52 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Use the search function and get a bunch of info, tech tips, links, etc.
Old Dec 18, 2007 | 02:55 PM
LD85's Avatar
LD85
see sig
Old Dec 18, 2007 | 03:54 PM
aklim's Avatar
aklim
Hood clearance?
Old Dec 18, 2007 | 06:15 PM
98Red's Avatar
98Red
Hi, this web site is very helpful. www.stealthram.com Good luck. You'll like it.
Doug.
Old Dec 18, 2007 | 08:27 PM
lumij3's Avatar
lumij3
Originally Posted by aklim
Hood clearance?
I have the oem hood and I did not know that I needed a high rise hood. How much is that going to set me back?
Old Dec 18, 2007 | 08:33 PM
aklim's Avatar
aklim
I bought a Greenwood Hood Scoop to make it work. You have to cut the HSR down (some have done it, don't know how) or you have to cut a hole in the hood and put a hood scoop on it.
Old Dec 18, 2007 | 08:52 PM
98Red's Avatar
98Red
Here's a couple of pictures. It's close but it won't fit under the stock hood.
Doug
Old Dec 18, 2007 | 09:02 PM
pablocruise's Avatar
pablocruise
will you be adding a hood scoop?
Old Dec 18, 2007 | 09:32 PM
98Red's Avatar
98Red
I already did.
Old Dec 18, 2007 | 09:45 PM
pablocruise
Wicked.
Old Dec 18, 2007 | 10:08 PM
lumij3's Avatar
lumij3
Originally Posted by 89 Paul in Cal
Wicked.
That looks radical. I might go with the greenwood option, I do not know yet it could be a deal bracker for me and decide not to install it after all.
Does the hsr makes any difference in performance on a otherwise stock engine?
Old Dec 18, 2007 | 10:09 PM
lumij3's Avatar
lumij3
Do you have pics to share.
Old Dec 18, 2007 | 10:20 PM
Curveit's Avatar
Curveit
There are other intakes out there that don't require cutting up the hood, and give better performance with your stock motor... Super-Ram, Mini-Ram for instance. The new BBK looks promising too.
Old Dec 18, 2007 | 10:53 PM
vinnies87's Avatar
vinnies87
FYI: There are Stealth Ram models that do not require hood mods, or custom made plenum that works...
Old Dec 18, 2007 | 10:57 PM
ross.rosseland's Avatar
ross.rosseland
What stealth ram model doesn't need a hood scoop? Are you talking the Joby mod?
I've been looking for fasterdeals.com but its website is down.
Where can I get a custom plenum to fit?
Old Dec 19, 2007 | 12:10 AM
Demonic85's Avatar
Demonic85
I'd make a sheet metal plenum for it instead.
To Holley stealth ram
Old Dec 19, 2007 | 12:13 AM
aklim's Avatar
aklim
http://www.hogansracingmanifolds.com/
That is one option
Old Dec 19, 2007 | 02:16 AM
comp's Avatar
comp
Old Dec 19, 2007 | 11:03 AM
lumij3's Avatar
lumij3
keep your thoughts coming
