How to adjust TPS sensor
Old Dec 20, 2007 | 04:20 AM
85L98-84L83's Avatar
85L98-84L83
Default How to adjust TPS sensor
My check engine light was on so I tested it and I replaced the TPS sensor. The light went out, and runs great now. Why do some people adjust it? Isn't it set from the factory? Or do you have to adjust them all? And how do you adjust it?
Old Dec 20, 2007 | 06:29 AM
rons85's Avatar
rons85
Depends. Are we talking about the '85 here?
If so - Yes, it must be adjusted, when you bolt it on there, to show a particular voltage (What exact voltage depends on what you are trying to do, the Factory setting would be .54) on a scan tool (or however else you choose to measure it) at idle. If you just slap it on there you have no idea what the voltage actually will be, and it's a relatively important input for the ECM.
Newer years (I'm not sure when it started - LT4 motors, maybe) do NOT have any provision for TPS adjustment, not mechanically anyhow.
Old Dec 20, 2007 | 08:43 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Your meter needs to be testing the 2 top wires on TPS. Shooting for .54 vdc +/- .075 vdc.
http://members.shaw.ca/agent86/TB-TPS%2bMin-Idle.pdf
If this is about your 84, I can't comment.
Old Dec 20, 2007 | 08:48 AM
85L98-84L83
Its on my maaco black budget 85.
Old Dec 20, 2007 | 09:10 AM
AGENT 86's Avatar
AGENT 86
I slip a brad nail along each wire and into connector. Put my meter leads onto to the nails (paper clips etc) and adjust the TPS till I get .54VDC.
Old Dec 20, 2007 | 10:13 AM
redrose's Avatar
redrose
90 and up the ecm resets from input to get ''0'' % throttle as long as voltage is .3-.9 vdc, MIL with be set if outside .3-.9v.
To How to adjust TPS sensor
