Balancer ?
Old Dec 20, 2007 | 04:51 PM
pipe's Avatar
pipe
Default Balancer ?
Will a 7 inch ATI Balancer clear my front crossmember in my 84 or do I have to go with the 6 inch ? I'm going to order it tonight. THANKS Pipe
Old Dec 20, 2007 | 08:13 PM
rodj's Avatar
rodj
Stock is about 6 3/4".
I would just buy the 6 3/8"ATI one to save the possibility of having to beat the clearance in the X member..
Old Dec 20, 2007 | 10:35 PM
pipe's Avatar
pipe
I'm not sure if they make a 6 3/8 Balancer. I saw in their Catalogue they have a 6 and 7 inch. I'll have to go back and look THANKS Pipe
Old Dec 21, 2007 | 04:49 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Pipe....nothing wrong with a 6" ATI or Fluid Damp. I run the latter and as long as the motor is internally balanced you will be fine with either. The ATIs are a little more expensive and I did some research and posted it a LONG time ago. The ATIs do not work as well in the lower rpms, below 6500, but shine above that.......however the difference is very little and doesn't really matter.
Sorry for the delay in getting back with you....I was traveling and have had very little time to be on here.
Old Dec 21, 2007 | 06:10 PM
pipe's Avatar
pipe
Jesse thanks for the reply I knew you had the right answer. I thought you would have a good Balancer on your car. How's the Straight Axle bolt in project coming? THANKS if both 6 and 7 inch both will fit I think i'll go with the 7 inch. A few more small items and the 383 will be complete Pipe
Old Dec 24, 2007 | 11:10 PM
pipe's Avatar
pipe
Was checking out some sites and it looks like TCI makes a good one "the Rattler" it's about 6 1/4" what about this one? Pipe
Old Dec 25, 2007 | 08:34 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
jim has that one on his car (85vet)
Old Dec 25, 2007 | 10:23 AM
pipe's Avatar
pipe
Thanks Cork that one is another option. I guess they all are pretty decent ATI, TCI and Fluidamper Pipe
To Balancer ?
