witch roller rockers?
Old Dec 20, 2007 | 06:26 PM
lushdrunk's Avatar
lushdrunk
Default witch roller rockers?
ive serched and dident find the answer im looking for.. what roller rockers should I get for a stock 91 l98? Im thinking 1.5 3/8 self align?
thanks
Old Dec 20, 2007 | 07:08 PM
dan0617's Avatar
dan0617
Self aligning narrow body roller rockers, preferably full roller not just roller tip, and for a performance upgrade go to 1.6 rockers. I bought mine from Summit Racing, they were the best deal. Don't forget to remove the drip tabs from the top of the valve covers inside. You can grind them off or just snap them off with vice grips. Some say to change springs and valve seals when going to 1.6 rockers, but I didn't and I didn't have a problem with my stock ones.
Old Dec 20, 2007 | 07:23 PM
lushdrunk's Avatar
lushdrunk
perfect, thank you.. 3/8" stud right?
Old Dec 20, 2007 | 07:29 PM
dan0617's Avatar
dan0617
Yes, 3/8" stud. If you don't get narrow body they won't work with centerbolt valve covers. And you need self aligning for your year vette. 1.6 rockers will give you a 10-15hp increase, and full roller rockers will give your engine less friction and a little lower oil temp. Summit sells nice blue anodized ones, they are pretty. It's sad to have to cover them up with valve covers!!
Old Dec 20, 2007 | 07:33 PM
lushdrunk's Avatar
lushdrunk
Thats the ones I was just looking at. I like the looks and price of them... thanks alot.
Old Dec 21, 2007 | 03:33 PM
dan_t's Avatar
dan_t
I don't suppose you can link me to the correct ones?
Old Dec 21, 2007 | 04:24 PM
ZD1's Avatar
ZD1
I used the CA-1318-16 COMP Cams Pro Magnum Roller Rocker Arms without clearance issues (except drip tabs). These are steel and run very well.
Though I made the mistake of keeping the 3/8 stud vice changing them out for the 7/16 version. If you thinking about stepping up in power later via better cylinder heads, the 7/16 will help to keep everything aligned.
For the record converted a head (fastburn) removing the guide plates and required ARP longer studs. The heads were raised port. The guide plates are not necessary for self aligning rockers...even the one used just for assembly as the L98 heads
One thing is common though is the need for a 0.100" longer push rod. Hyd lifters forgive up to 0.050ish of improper length, but the 0.100" will help get in the ball park. Read up on how to properly check contact pattern with the valve tip.
Old Dec 21, 2007 | 04:32 PM
C4Rich's Avatar
C4Rich
Cruising
what should i look for for my LT1?
Old Dec 21, 2007 | 05:08 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I found a set of Crane Gold 1.6 RR, narrow body, self aligning for my LT1. I did change out the valve springs and seals while I was at it.
Old Dec 21, 2007 | 09:19 PM
Midnight LT4's Avatar
Midnight LT4
I'm planning on using the GM Performance Parts roller rockers with the GMPP studs unless anyone knows about rebuilding factory LT4 rocker arms. The roller bearings are rough and would need to be replaced. Also one managed to jump off the valve tip and needs to be totally replaced as the body of the rocker arm is damaged.
Old Dec 29, 2007 | 05:54 PM
Calderone's Avatar
Calderone
i wonder if there is a problem with the edelbrock elite centerbolt valve covers
Old Dec 29, 2007 | 07:07 PM
STL94LT1's Avatar
STL94LT1
I would check valvetrain geometry before buying longer pushrods. Most will need a shorter pushrod with increased lift.
Old Dec 29, 2007 | 08:24 PM
Travis93's Avatar
Travis93
I also went with the GMPP 1.6 rockers. Seemed like the best balance of cost performance and reliability. I was going to go with the proform "blue anadized ones" but read a lot of bad things about them like the bearings coming apart.
Old Dec 30, 2007 | 11:00 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Put in a set of LT4 101# valve springs (about $35).
Old Dec 30, 2007 | 11:50 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Midnight, there were some recalls on the early production LT4s for bad rockers. Check to see if your VIN falls between these numbers'
: 5100052 through 5102717 for the first recall
: 5100052 thru 5111116 for the second recall.
The LT4 also uses 10mm studs. Unless you plan on changing them out to 3/8 or 7/16 you'll have limited choices on rockers.
Old Dec 30, 2007 | 12:14 PM
Strick's Avatar
Strick
I installed Crane's Gold narrow body self aligning roller rockers on my LT1. I stayed with the 1.5 ratio as Crane said coil bind might be a problem with the 1.6 rato. A set of LT4 springs would take care of that. Also crane required different pushrods for the roller rockers. At the time, I didn't know much about tuning the ECM so I stayed with the OEM ratio rockers. These 1.5 rockers will be going to my son's Camaro and I'll be upgrading to 1.6's now that I know what has to be done. BTW, the gold ones look good, too.
Old Dec 30, 2007 | 12:18 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
That's what I used. I used Comp guide plates. I got the non-self aligning version since I had guide plates.
I'd measure the pushrod, don't just pick one.
Old Dec 30, 2007 | 12:22 PM
Sidney004's Avatar
Sidney004
I used the Crane Gold 1.6, new LT4 Valve springs and seals, new pushrods(same length as stock,)dremel tooled the drip tabs off. Worked perfectly.
Old Dec 30, 2007 | 12:26 PM
STL94LT1's Avatar
STL94LT1
I've used Crane Gold 3/8 1.6 self-aligning, Comp Cams Pro Magnum 3/8 1.6 self-aligning, and currently running Comp Cams Pro Magnum 7/16 1.6 non self-aligning roller rockers. They are all a quality rocker, but it seemed like the Cranes were a bit quieter.
To witch roller rockers?
