Quick question
Old Dec 21, 2007 | 10:53 AM
vette'n's Avatar
vette'n
Default Quick question
What is the torque spec for the intake bolts on a 92'. The Haynes Manual I have gives me the sequence but not the torque spec. Thanks!
Old Dec 21, 2007 | 11:28 AM
Iroc57's Avatar
Iroc57
My 91' FSM has 35ftlbs except for positions 1 and 4 that are 45 ftlbs
If yours is an LT1 i would wait for one of those guys to chime in though
Old Dec 21, 2007 | 07:12 PM
vette'n's Avatar
vette'n
Yeah. The last time It was completed. I am fairly sure that the torque was about 65 ft lbs....... anyone? 65....66.....67?
Old Dec 21, 2007 | 07:34 PM
purplewindworm's Avatar
purplewindworm
65 sounds a little high for aluminum. I dont want to sound mean, but you really really should pickyou up a factory service manual. You can pick them up off eBay for about half price. Be sure that Helm, inc is the publisher. Sorry, I am at work or I would look it up for you, but 65 sounds high.
Onion Rings
Old Dec 22, 2007 | 12:09 PM
vette'n's Avatar
vette'n
Anybody else know? I could have swore that it was in my Haynes manual. Now I have it all apart and no damn numbers. The last time I did it I am almost certain it was about 60 something. But I'm thinking that I should confirm before I break something. appreciate any help
Old Dec 22, 2007 | 01:19 PM
MMOCguy's Avatar
MMOCguy
Assuming yours is an LT-1 (J Code), here are the specs:
MAP sensor bracket-to-plenum screws = 89 InchPounds
Throttle body-to-plenum screws = 19 FootPounds
Throttle body extention-to-plenum screws = 53 InchPounds
Ignition module-to-plenum screws = 89 InchPounds
Intake plenum bolts = 19 Foot Pounds
Hope this helps.
Norm.
Old Dec 22, 2007 | 01:24 PM
Usfive's Avatar
Usfive
My '92 FSM states intake manifold bolts/studs for LT1 engine first pass in sequence is 8 N*m [71 LB. in. (THAT's INCH NOT FOOT)].
Second and final in sequence is 26 N*m [19 lb. ft. (now it's FOOT NOT INCH)].
It your torque wrench is set with metric go with that.
To Quick question
