anyone make there own airpump delete brackets?
Old Dec 22, 2007 | 10:17 PM
all show and more go's Avatar
Default anyone make there own airpump delete brackets?
i was looking to make my own, and was wondering whats parts might have been used?
Old Dec 22, 2007 | 10:37 PM
redvette6spd's Avatar
redvette6spd
I think there was a member here who gutted there pump and that did the trick but I have no idea who it was or how long it lasted.
Old Dec 22, 2007 | 11:23 PM
mines gutted but i jus wonna get rid of it(weight loss program!)
Old Dec 22, 2007 | 11:25 PM
edoad's Avatar
edoad
If you search AIR Pump delete bracket you will come up with a lot of good ideas.
Old Dec 22, 2007 | 11:59 PM
Plasticman's Avatar
Plasticman
Here is the one I designed and made. Korvette4U sells a version of it, but current price is unknown (and rumored to be high). I am debating on making/selling it myself (and selling it cheaper). Other option is I can send cad files to anyone interested in making it themselves, but the cad files are in CadKey, which is no longer in business. This version does require a shorter belt, due to my design goal of keeping the alternator in the stock position (to maintain proper support with the stock rear tube bracket), but lowering the pulley position to keep the bracket(s) that support the new idler pulley as stiff as possible.
Plasticman
Old Dec 23, 2007 | 08:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here's a pic of my home build. It uses the stock belt and alternator location.
Old Dec 23, 2007 | 09:04 AM
87 rag's Avatar
87 rag
Looks good Dan but I thought it would have more yellow on it.
Old Dec 23, 2007 | 09:23 AM
AGENT 86's Avatar
AGENT 86
Your right, I think I better powder coat the insides of the cross flags, yellow. Thanks for pointing that out
Old Dec 23, 2007 | 09:47 AM
87 rag's Avatar
87 rag
You were already thinking about this, weren't you?
Plasticman, yours looks great too.
I'm also in the process of making a bunch of changes to my engine and I'm having the air pump delete debate with myself.
Considering I just accidentally broke all the air tubes off my passenger side header, the air pump delete side is winning the debate.
Old Dec 23, 2007 | 09:51 AM
AGENT 86's Avatar
AGENT 86
Actually, I wasn't. But I do like the idea.
Old Dec 23, 2007 | 02:18 PM
pablocruise's Avatar
pablocruise
I made a really crude one.
Just got some bar stock, some spacer tubing(steel), the necessary bolts, and a pulley from NAPA.
I probably spent under $20 for it all.
hard to see but.....
works fine, but will not be entering into any car shows.
Old Dec 23, 2007 | 04:45 PM
Plasticman's Avatar
Plasticman
One of the issues that came up when I was designing mine, was the reported problem of broken off alternator case mounting tabs (upper tab where the OEM bracket supports the tab on both sides). This was one of the reasons I designed it with 2 plates. Other designs that I have seen are a single plate, but with a fork coming off of the plate to go around and support the alternator tab on both sides.
If the alternator mounting tab breaks off, the housing is trash, and a vendor will not accept it as a "core".
The other issue was to keep the rear mounting bracket as it helps support the alternator from twisting (another potential cause of broken tabs).
Plasticman
Old Dec 23, 2007 | 09:45 PM
XQIZT's Avatar
XQIZT
how much does the pump actually weigh? i just gutted mine and its been fine for several years.
Old Dec 24, 2007 | 09:56 AM
Chapindad's Avatar
Chapindad
Plasticman
Let me know if you decide to make more. I would be interested in one.
Old Dec 24, 2007 | 10:32 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Here's mine, some flat stock, tubing, and a pulley from NAPA that is for the C5 tensioner. Of course there's welding involved unless you just want to bolt it together. [IMG][/IMG]
Old Dec 24, 2007 | 11:52 AM
Plasticman's Avatar
Plasticman
To the forum member that sent me an e-mail, requesting the cad files, please resend your e-mail to me. I "lost" your e-mail address in a computer glitch.
Plasticman
Old Dec 24, 2007 | 12:45 PM
nutz4c4's Avatar
nutz4c4
To the forum member that sent me an e-mail, requesting the cad files, please resnd your e-mail to me. I "lost" your e-mail address in a computer glitch.
Plasticman
Sent you a PM
To anyone make there own airpump delete brackets?
Old Dec 24, 2007 | 01:14 PM
Plasticman's Avatar
Plasticman
Still thinking about it. Probably make up my mind after the holidays, and will keep you informed.
Thanks for interest,
Plasticman
Old Jan 2, 2008 | 11:05 PM
korvette4u's Avatar
korvette4u
this modified single plate design is one piece ridged fixed that i build, it takes about 4-5 hours to completed one unit ,Custom Machined aluminium pulley, with replaceable bearing and is complimented by "satin natural finish" aluminium plate.This unit will replace the existing air pump in your 84-91 Corvette with L-98 engine, lowering it into the engine compartment. Later this year i will anodize red ,blue, clear making these one of kind.
Single plate..
Mounted
Another view
back view
Old Jan 3, 2008 | 01:05 AM
86PACER's Avatar
86PACER
Plasticman
That's a nice piece.
