Brake Pads
Old Dec 25, 2007 | 05:08 PM
jan-erik's Avatar
jan-erik
Hi. I havean 85 z-51 manual and the brakes were terrible. I was shocked how bad they were in comparison with european car normal car brakes. I changed to semi metal pads no real difference and then metal brake lines.that made the pedal a better feeling. Then I changed to new rotors in front and EBG greenstuff pads. That made a big difference in normal street (daily drivers) braking. But higher speeds not very good. The 85 has single piston calipers no ABS and I wonder how slotted rotors and Hawks are. I drive it in daily drivers modus with a little progressive driving now and then needing better brakes. Can anybody recommend a combination
Old Dec 25, 2007 | 11:15 PM
Ajaste's Avatar
Ajaste
Originally Posted by Steel Blue 91
I use the Performance Friction (PFC) Carbon Metallic with good results on the street. ~$70.00 front and rear from Autozone. First stop or two is a little long until they warm up.
ditto
