Brake Pads
Old Dec 23, 2007 | 12:43 AM
Demonic85's Avatar
Demonic85
Default Brake Pads
I'm in need of new front brake pads (the rears are just fine as are all 4 rotors) and was wondering what you guys would recommend. I see Autozone carries Duralast semi-metallic pads for $20. Sounds good to me, anybody use these before?
Old Dec 23, 2007 | 01:33 AM
80sRule's Avatar
80sRule
Absolute trash. I used them on my 87 until my Hawk HPSs came in. In less than 1k miles they were quite used up.
The HPSs at PepBoys are about $80, but if you go to college, most will give you a 10% discount. Great pads.
Old Dec 23, 2007 | 01:54 AM
Demonic85's Avatar
Demonic85
I'm not sure whats on there now, previous owner put new pads on right before I bought it, they've lasted 7K miles and are down to the metal already. I've never seen brake pads get used up like that. I'll check out the Hawk pads. Thanks
Old Dec 23, 2007 | 08:30 AM
GS4-LT1's Avatar
GS4-LT1
Wagner Thermoquiets. Best pad for the money. No noise, no dust and great stopping power. They should be around $50.00, stay away from the "Store Brands" I have tried almost all of them and they all are trash.
Old Dec 23, 2007 | 08:46 AM
Plasticman's Avatar
Plasticman
Had Raybestos (Brute-something??) pads on my 87 with the J55 front conversion with 13" rotors & 2 piston calipers, and was never pleased. Switched to the Hawk HPS pads recently, and they show a very significant difference in pull down power, and recommend them highly.
Note that the Hawk pads did not show any stopping power change when installed on the rear stock brakes (I changed them 1st), but then again, I don't think the rear brakes do anything (they hardly stop the rear wheels from turning when on jack stands and in 1st while @ idle).
Plasticman
Old Dec 23, 2007 | 09:58 AM
dan0617's Avatar
dan0617
I bought a slightly used (yes, I'm cheap) pair of Hawk HPS pads from a forum member, and a pair of slotted (not drilled) rotors from Hawks racing (not related to Hawk pads) from ebay since my rotors were warped. I sanded the pad surface with 80 grit since they were used, then installed everything and bedded them in as per instructions on the Hawk pads. The brakes are exceptional. I can make the 275/40/17 tires squeal if I'm going 90mph and floor the brake as hard as I can. I've never had a car stop like this one, and it wasn't that way before the brake and rotor swap. I never changed the rear pads or rotors as they seem to work ok. When they need done guaranteed it will be Hawk HPS
If you are interested in used, search the parts for sale section. There was a pair on there not very long ago I think. If you don't find any you could put up a wanted to buy. Used go for about 1/2 price and sometimes (in my case) have 90% life left in them.
Old Dec 23, 2007 | 03:43 PM
runner140*'s Avatar
runner140*
I tried a few compounds until I tried Hawk HPS. Soft enough for good stopping but hard enough not to dust to bad.
Old Dec 23, 2007 | 04:11 PM
jon0108's Avatar
jon0108
i use wagner thermoquiets in all my cars
Old Dec 23, 2007 | 09:32 PM
Demonic85's Avatar
Demonic85
I did a store search for the Hawk pads and the only place within 50 miles that carries them is Tire Discounters. I'm not sure they would sell them and not install them.
I found them at Jegs, but they're $80 for the front pads alone?
Old Dec 23, 2007 | 09:53 PM
Steel Blue 91's Avatar
Steel Blue 91
I use the Performance Friction (PFC) Carbon Metallic with good results on the street. ~$70.00 front and rear from Autozone. First stop or two is a little long until they warm up.
Old Dec 23, 2007 | 11:10 PM
80sRule's Avatar
80sRule
Love them on my Lincoln Town Car. They work great, but was unable to find them to fit the 84-87 Corvettes. If I would've been able to, I would have used them.
Old Dec 23, 2007 | 11:22 PM
edoad's Avatar
edoad
My 85 seems to have stiff brakes. Somewhat excessive brake force required. Could this be pads or is this normal for an 85?
Old Dec 23, 2007 | 11:27 PM
Demonic85's Avatar
Demonic85
They're supposed to be stiff. My pads are wearing thin and it takes longer to stop now. Mine are almost down the metal but are not making any grinding or squealing noises. If in doubt replace them, its not worth wrecking over.
Old Dec 24, 2007 | 12:56 AM
evmlarry's Avatar
evmlarry
7k, eh? I wonder if it's bad pads or perhaps a sticking caliper?
Old Dec 24, 2007 | 12:58 AM
Demonic85's Avatar
Demonic85
Thats what i've thought too because when I jack the car up, the front wheels seem to drag a little instead of free spinning like the rears. Either way I was going to check it out when I got new pads.
Old Dec 24, 2007 | 04:41 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
The GM pads are pretty damn good and priced right. I have them on my Z51 and they stop great.
Old Dec 24, 2007 | 06:30 PM
96vetteLT4's Avatar
96vetteLT4
Default Hawk
Get the Hawk pads. Its a Corvette for gods sake, spend 100.00 and put some quality brake pads on it. Why wouldn't you put a performance pad on your car? The price difference between a junk set from Pep Boys and a performance set is maybe 50.00. Thats almost the price of 1 good tank of gas....get the Hawks...
To Brake Pads
Old Dec 25, 2007 | 07:40 AM
badabing9's Avatar
badabing9
http://forums.corvetteforum.com/show....php?t=1769573
Old Dec 25, 2007 | 01:43 PM
rfn026's Avatar
rfn026
Default Autozone Pads
I used Performance Friction on my track car for several years. I got them at Autozone and they came with a lifetime guarantee. Since I run a lot of track events I used to replace them every few months. I think I got about 10 sets of front pads and only only paid for the first set. I just love lifetime warranties.
Lately I've been using Wilwood A pads all around. They were designed for Bristol and they really stop the car. The only problem is they eat brake rotors. The pads actually outlast the rotors. Also, you've never seen brake dust like this. A couple hours on the track and my wheels are totally black - but damn do they work.
Keep in mind that my front brakes are running around 1100-degrees at Sebring. That's hot. Then again I'm driving into turn 17 at Sebring at about 145 miles an hour.
Check out the Autozone near you if you have a street car.
Richard Newton
101 Projects for Your Corvette 1984-1996
Old Dec 25, 2007 | 03:28 PM
Danspeed1's Avatar
Danspeed1
Default Hawk - EBC - Performance Friction
I use hawk in everything except my beater. Did the rear brakes on our 89 vette about a month ago. I had a frozen caliper so replacing both the rear calipers made a huge difference, but I think the HPS pads I am using also helped alot,... the car stops quick and theres very little if any dusting. For the front, I am doing a C5 conversion, I might try the HP+, not sure, but either way I will install hawk.
My friend uses EBC's on his LS1 GTO,... car stops so quick it could put your head through the windshield, but than again hes got a $4K Big Brake Kit.
I have a 95 Monte with 167K,... and horrible brakes, I will give performance friction a try on that one. Heard they work well, and they are alot cheaper than the hawks. On a car thats worth $600 I don't think its is worth putting $100 pads on.
DG
