383 oil pan
Old Dec 23, 2007 | 02:41 PM
86malcomekonnner's Avatar
86malcomekonnner
Default 383 oil pan
my buddy is putting a 383 in his lt1 camaro...i know this isn't the place for this car but i figured you guys would probably have an answer for this. He is having a clearance problem with the oil pan against the crank.. is there an aftermarket pan he can get or should he just bang out the pan a bit? thanks
Old Dec 23, 2007 | 02:47 PM
Pete K's Avatar
Pete K
There are dozens of aftermarket pans, or he can use the BFH to pursuade the stock pan to fit.
Old Dec 23, 2007 | 08:04 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Just be careful using the BFH, I was on my last clearance dent when the pan cracked. I ended up using a Canton pan.
Old Dec 29, 2007 | 04:50 PM
86malcomekonnner
i personally went and looked and this clearance problem with the oil pan...and the oil pan isn't even close to the crank...it looks like what i would call a crank scraper, is hitting the bolts on the rod caps. i would assume that its as easy as just banging that out a little bit...or could something like that just be removed...thanks guys
To 383 oil pan
