Brake Fluid Disappearing
Old Dec 27, 2007 | 06:11 PM
cgb86c4's Avatar
cgb86c4
Default Brake Fluid Disappearing
In the past few weeks I have had to fill the resevoir on the master cylinder twice. the fluid is disappearing somewhere, I checked all the lines and calipers and the ABS pump, and they all dry. Does anyone have any ideas.
Old Dec 27, 2007 | 06:25 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Power brake booster perhap?
Check both the vacuum line, and remove the master cylinder from the booster.
Also see it it's not leaking into the passenger cabin.
Old Dec 27, 2007 | 08:35 PM
Corvette40's Avatar
Corvette40
My 88 was doing the same thing. I had to replace my booster and found the fluid weeping out between the booster and master cylinder. If I hadn't removed the booster I would probably still be looking for the leak.
Old Dec 27, 2007 | 08:47 PM
Bob CTS's Avatar
Bob CTS
Old Dec 28, 2007 | 11:02 AM
cgb86c4's Avatar
cgb86c4
It's the master cylinder. Thanks for the help.
Old Dec 28, 2007 | 03:51 PM
89 Bob L's Avatar
89 Bob L
The fluid is most likely going from the rear of the master cylinder into the brake booster.
To Brake Fluid Disappearing
