Code "H61" on a 1995 (?) Help!
Old Dec 28, 2007 | 10:29 PM
Gary6595's Avatar
Gary6595
Default Code "H61" on a 1995 (?) Help!
Yes, I received a Code "H61" when I retrieved codes via the paperclip method. There is NOT a code 61 in ANY of my manuals, in any of the forum threads, or even in any of the "F" Body websites. Yes, I am sure of the number - even checked it twice (like Santa does his list). Does anyone have a clue?
Prior to struggling back to the garage, heavy black soot was coming out of the tailpipe and covering the entire rear of the car. I checked a few fittings and generally shined the flashlight around (like THAT was gonna help) . . . Now it runs fine.
C'mon guys/gals - someone has to know what's going on here . . . lol
Thanks in advance, Gary
Old Dec 28, 2007 | 10:46 PM
RRT vette's Avatar
RRT vette
I did an advanced search and could not find a DTC #61 for the 94-95 Corvette. What module was it found in (1,4,9) and what was your prodecure of pulling the codes?
From the description, it sounds like a O2 sensor code.
Old Dec 28, 2007 | 10:55 PM
Gary6595's Avatar
Gary6595
Thanks for the reply. My '95 has the 16 pin ALDL and I paperclipped #4 and #12 terminals, per research in various C-4 threads. There were four codes set: H64 in Module 4; and in module "A", H24, H61, and H62. I am not sure what Module "A" is, but that was the read-out on the dash display. I even ran the sequence again to make sure.
Now, this is the first time I have pulled codes because it is the first time I have had ANY problem with this pristine 47,000 mile car. So, the other codes may be ancient history. But factoring in the sputtering and smoking, I guessed that maybe the O2 sensor was a culprit. But I could not find an H61 code anywhere.
Thanks, Gary
Old Dec 28, 2007 | 11:02 PM
RRT vette's Avatar
RRT vette
You might want to disconnect the neg cable on the battery for ~15 sec to clear the codes. Start the engine and go for a short drive and pull the codes again. See what shows up.
You are correct. The 94-95 are OBDI with the 16 pin ALDL and you used the correct terminals to pull codes. The 96 changed to OBDII and still has the 16 pin ALDL. I haven't seen a module "A" before in any refrence either. The H means it's a history code, and a C means it is a current code.
If the black soot was coming from just one side of the exhaust, I'm betting one of the O2's has died. Just can't do much with a code that doesn't exist on paper.
Old Dec 29, 2007 | 12:31 AM
VenkmanP's Avatar
VenkmanP
Not a ZR1 is it? A quick search shows that they have a DTC 61.
Your description of the driveability problems does not sound like an O2 problem, because an O2 failure that causes problems that bad will throw it into open loop and the problems will then clear up.
But given that it is throwing a mystery code, we can't assume that the PCM is operating correctly, so this may not hold true in your case.
Getting a scanner on it to see what the O2s are doing would be a good idea. Short of that you can unplug the front O2s and see if it improves.
Old Dec 29, 2007 | 01:16 AM
Gary6595's Avatar
Gary6595
Vis: Thanks. No, sadly not a ZR-1. I was under the impression that a failed O2 would actually cause a lean versus a rich condition.
RTT: I think I will follow that plan and then pull codes afterward. Worst that can happen is that I will lose my radio presets, lol. I recall seeing the "A" module reference somewhere, but I have not been able to find it.
Rest assured all that I will post my results here and the description of the "H61" code, and the "A" module. This is totally weird, but like I said, today the car ran fine with no sooty exhaust. Gremlins maybe?
Thanks again to both of you. Gary
Old Dec 29, 2007 | 11:28 AM
Red Dwarf's Avatar
Red Dwarf
If memory serves...the CCM has a code 61. Something to do with the pass key programming circuit???????
Old Dec 29, 2007 | 12:48 PM
Gary6595's Avatar
Gary6595
Thanks again to all. I located the "A" module reference in another Forum thread:
Finally, Module "A", the DERM (Dynamic Energy Control Module --- the air bag control module) will be requested to show any codes.
My air bag light comes on occasionally, so that may be it.
Bottom line: none of the codes that I retrieved relate to the condition that I encountered the other day - sputtering and heavy black sooty exhaust. Plus, my "check engine" light came on a few times and then went away. Car runs OK now. Strange?
I may have to dig deeper - maybe even call Gordon Killebrew for answers, lol.
Thanks again, and stay tuned. Gary
Old Dec 29, 2007 | 01:00 PM
Gary6595's Avatar
Gary6595
In re-reading RRT's reply, the black soot came from BOTH exhaust pipes, leading me to believe that not one O2 sensor is bad. Moving up the chain, something caused this over-rich condition (like when a power valve sticks on an old Quadra-Jet) then it went away, but no code was set.
To erase the codes, all I do is disconnect the negative battery cable for ~15 sec - that simple???
Old Dec 30, 2007 | 06:35 AM
Casethecorvetteman's Avatar
Casethecorvetteman
I have posted a reply in the other forum you posted this.
Old Sep 6, 2008 | 09:29 PM
formul89's Avatar
formul89
I am getting this H61 code also.
Another thing is I disconnect the battery or manually clear the codes and these H codes keep returning. It never gets any C codes.
I'm stumped.
Old Sep 6, 2008 | 11:47 PM
MK 82's Avatar
MK 82
Why are you resurrecting these dead threads? If you have a question, start a new thread.
To Code "H61" on a 1995 (?) Help!
