valve cover input needed
Old Dec 30, 2007 | 07:28 PM
xrcrx's Avatar
xrcrx
Default valve cover input needed
i've built a 383 for my '84 and have 1.6 full rollers.
Any suggestion on centerbolt valve covers that'll clear the rockers and the wiper motor? Apparently "tall" covers won't clear the wiper motor.Thanks in advance.
Old Dec 30, 2007 | 07:38 PM
Chatman's Avatar
Chatman
Can't you use perimeter bolt valve covers (studs actually aren't they)? The tall Proform polished perimeter with slanted ends has worked for many people, including me. But, mine is an 86. Which intake are you using?
Old Dec 30, 2007 | 08:03 PM
xrcrx's Avatar
xrcrx
Edelbrock Performer for now-Shhhh.... Temporary Carb till I can tune-kinda busy w/lymphoma at the moment and just wanna drive it.
Old Dec 30, 2007 | 08:06 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Proform makes a "tall" cover that is 1/4 inch higher than stock. As far as I can tell, these have no fitment problems with the rockers, AC compressor, or wiper.
Here's the ones I got.
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 30, 2007 | 08:10 PM
xrcrx's Avatar
xrcrx
No need to cut out the baffles?
Old Dec 30, 2007 | 08:26 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default covers
um, no more technical information for you until you clean up that messy garage
Old Dec 30, 2007 | 08:28 PM
jsup's Avatar
jsup
Not if they are narrow body rockers.
Old Dec 31, 2007 | 12:18 AM
xrcrx's Avatar
xrcrx
Not my place but was shaped up after the other projects were moved out for mine.
Old Dec 31, 2007 | 01:25 AM
eguyett1985's Avatar
eguyett1985
I have the GMPP short aluminum perimeter bolt covers on my 85 and I had to trim the cover on my wiper motor for clearance which totally bugs me. I'm working on adapting another wiper motor that should work with even really tall covers. Once it's working I'll post some pics.
Old Dec 31, 2007 | 01:28 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You can use any old style 4 bolt valve covers that are aftermarket tall.
Mickey Thompson makes the ones most used. I have those and a set of Moroso that are tall tin and the MT are alum.You will have to remove the wiper motor which everway you go .I ground the feet off of my wiper motor reinstalled the rubber feet and plugged it in after I installed the valve cover and that is it.DO NOT INSTALL THE ENGINE WITH THE WIPER MOTOR IN PLACE !!REMOVE IT FIRST AND THEN INSTALL THE ENGINE.
The parts are not only hard to find for these cars but expensive.
I also use the valve cover gaskets from MR gasket,with the steel in the center and a cork materal on the out side ,expensive but they will almost never need to be replaced.I have a solid cam in my 86 and I always have the covers off.Don't cut the black cover, dirt will get into the electrical and screw it up over time.
Have a Happy New Year
Old Dec 31, 2007 | 02:21 AM
xrcrx's Avatar
xrcrx
Thanks for the input
Old Dec 31, 2007 | 02:50 PM
xrcrx's Avatar
xrcrx
Ended up getting Billet Specialties tall/perimeter bolt/ ball milled w/bowtie.
Old Dec 31, 2007 | 03:33 PM
Pete K's Avatar
Pete K
Best wishes in the new year
Get well, my friend.
Old Dec 31, 2007 | 03:43 PM
xrcrx's Avatar
xrcrx
Thank you. Best wishes to you and your family and a Happy New year to everyone here!
To valve cover input needed
