ZR3 laser shifter
Old Dec 30, 2007 | 09:25 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default ZR3 laser shifter
These babys are suppost to work.............installation is 2 sending units on the front end and on 1 above the rear licence plate........I wonder if I could use the rubber suction cups and mount 2 on the windsheild and 1 on the rear window...........that way I could use them on all my cars and if pulled over I could remove them ..............any thoughts or experiance with them?
Old Dec 30, 2007 | 10:51 PM
badabing9's Avatar
badabing9
would they work?, yeah but only after they already clocked you! laser is aimed at the front plate area first, then any visible headlights/headlight area, then hood area and last the windshield. the units are supposed to be mounted perfectly level and straight to work properly.....the laser is approx 18'' wide at a specific distance so, if mounted on your windshield it'll be an exercise in futility.
