Super Ram Install....
Old Dec 31, 2007 | 08:28 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by John A. Marker
Yes, the studs screw into the plenum without a nut. Most studs have a section in the center that is not threaded so the stud screws in tight up to this point. The studs have two different threads, one set that matches the plenum threads (coarse) and the threads for the nuts are fine.
That sounds like the way to go.
Old Dec 31, 2007 | 09:32 PM
tequilaboy's Avatar
tequilaboy
1 minor correction to ensure you get the correct fasteners: The SR plenum threads are fine (1/4-28) and the nut threads are coarse (1/4-20).
I have a box of 100 1/4-20 kep nuts on hand, so let me know if you need some or have trouble finding them.
Old Jan 1, 2008 | 11:09 PM
CRV3TT3's Avatar
CRV3TT3
Youve been a huge help so far. My superram is suppose to show up tomorrow and the studs on friday!
...is there anything special i should look into getting to make the install a little smoother? I read on thirdgen.org the stock throttle bracket doesnt work with the kickdown cable?
Old Jan 1, 2008 | 11:16 PM
Kevin 88's Avatar
Kevin 88
The kit comes with a new bracket.
Old Jan 1, 2008 | 11:25 PM
jsup's Avatar
jsup
What if you got the kit used and don't have said bracket.
It looks as if my original bracket will work, but I won't know until I go to screw it on.
Old Jan 1, 2008 | 11:45 PM
aklim's Avatar
aklim
Call Lingenfelter or Accel. They might be able to help you. My manifold got broken by some clown and they sold me one.
Old Jan 1, 2008 | 11:48 PM
Kevin 88's Avatar
Kevin 88
When I installed mine I got the brackets mixed up and found out when I couldn't get the TV cable in. It jams right into the plenum.
I looked at both parts just now. I think the stock bracket will work if you put it in a vice and make the angle a little sharper - then oblong the lower bracket hole with a file.
Old Jan 1, 2008 | 11:57 PM
aklim's Avatar
aklim
Sounds about right.
Old Jan 2, 2008 | 12:01 AM
jsup's Avatar
jsup
Thanks. I'll have to wait till I get it together to see how it fits..
As for vacuum connections.
There's a provision for three on the back of the intake:
1. To the fuel pressure regulator.
2. To the thing (forgot technical term) that mounts right over those holes
3. To the firewall for the internal vacuum devices, like air diversion doors.
Do I have that right?
Old Jan 2, 2008 | 12:03 AM
aklim's Avatar
aklim
Sounds like you manifold absolute pressure sensor. You do have speed density, right? If not, I would plug it off.
Old Jan 15, 2008 | 10:12 PM
jsup's Avatar
jsup
Thanks guys. I studded the plenum and I'm waiting on the gaskets.
I had a problem with the threads on the manifold, I had to re tap them, that's why I needed to order new gaskets.
