EM Long Tube Headers
As I've heard that with the LT's this deletes the cat's and makes passing emmision tests a problem?
Is this true?
Mark
Here is a comparable set of cats for an even a better deal than the Dynatechs. If you are going to use the slip-fit method you'll need the 3" version.
http://flowmonster.com/mm5/merchant...._Code=metallic
to whatever rubber material is used.
Also keep in mind that heat causes significant growth in the exhaust
system, not just in dia but in length, too. My vote is that anything
that inhibits the freedom of the exhaust to expand when it is hot is
likely to impart stress that may lead to premature cracks.
As for spacing the X-brace. Instead of using flat washers, consider
fabricating shims from sheet or plate stock that closely approximate
the shape of the contact surface of the OEM mounting points. This
increases the clamping area and helps the bolts continue to work in
tension rather than in shear.
the passenger compartment can become hot enough to scorch and
even ignite the tunnel/floor.
My vote is that conventional rubber-like materials are going
to suffer by or beyond temperatures of 300ºF. If there was
some air space between the heat source and the rubber object,
this would help but direct contact would result in short life.
Some silicones have better heat resistance. The popular silicon
oven mitt claims to protect to 500ºF.
However, best results would be realized with the heat-resistant
material sold by companies like Thermo-Tec and DEI. Fiberfax
makes ceramic fiber insulation that is widely used for kilns,
chimneys and various industrial applications.
FWIW, 2-1/2" collectors work well with an R-D brace on an
'89 coupe.
a shape intended to provide a balance of lightness and
longtitudinal stiffness. Take a long narrow strip of cardboard
and check how it flexes, then form it into a shape similar to
the legs of the x-brace. The formed version will be stiffer.
As for hijacking - you are commenting about EM headers on
an LT1, maybe the OP has a convertible, too?
Edit to change spelling to Thermo-Tec from ThermoTech
I run the same setup and passed KY emissions (when we used to have it).
