Front Wheel bearings
Old Jan 2, 2008 | 11:11 AM
DonF's Avatar
DonF
Default Front Wheel bearings
My front wheel bearings on my 96 have a little play in them, OK for street but I plan to Auto X this car & don't want any prob. w/Tech. My question is I was told that the same wheel bearings are used on the S-10 pick up, does anyone know if this is true? The best price that I found for a quality bearing for the Corvette is $298.00 from an auto parts store, anyone know of a better price any where? Thanks, Don
Old Jan 2, 2008 | 11:27 AM
c4cruiser's Avatar
c4cruiser
Don't know about the S-10 but you might read this thread. When I replaced a front bearing on my 87, I used a Timken?BCA #513019 bearing and it cost me about $150. The 91-96 bearings run a little more
Old Jan 2, 2008 | 01:48 PM
DonF's Avatar
DonF
Thanks, intresting.
Old Jan 2, 2008 | 01:55 PM
jrp's Avatar
jrp
Lots of good stuff in that linked thread.
I chose to use the F-body fronts on my '96 and came out ahead, even counting the drill press I had to buy.
Old Jan 2, 2008 | 02:07 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Roller bearings, as oppose to the ball bearings we have stock, are out.
The front's will be comming shortly
http://forums.corvetteforum.com/show....php?t=1880188
Old Jan 2, 2008 | 03:39 PM
black_771's Avatar
black_771
Standard S10s had regular bearings where my Corvette has a bearing hub assembly. The Blazer Extreme has a hub assembly like the vette, but I have no idea if it will fit the vette.
I know this because I changed my S10 bearing and knuckle assembly over to the sealed hub assembly when I put larger Extreme front brakes on my truck.
**EDIT**
I looked up the pic on Ebay, the Extreme front bearing assembly is definitely different.
Old Jan 2, 2008 | 07:14 PM
Tom Piper's Avatar
Tom Piper
The '96 front bearing has an ABS reluctor ring.
Does the S-10 bearing have it?
Tom Piper
Old Jan 3, 2008 | 08:53 AM
black_771's Avatar
black_771
Hmm, so I understand what you are actually asking, I'll rephrase my first post and say that the S10 just has a regular inner and outer bearing that needs to be packed with grease every so often. The Blazer Extreme has the sealed hub does have the reluctor ring, but it is inside the sealed hub assembly. The picture of the corvette hub that I saw looked as if the reluctor ring was on the outside or the hub was some how able to be separated. Not sure if this is helping or not. Let me know.
Old Jan 3, 2008 | 11:31 AM
BrianCunningham
Here's what it looks like w/o the sensor attached,
but late model cars should come with it. Here's a pic one with the sensor.
In the back the ring is on the subaxle.
Old Jan 3, 2008 | 11:38 AM
black_771's Avatar
black_771
The Extreme is definitely different from the Corvette. Not even close.
Old Jan 3, 2008 | 02:44 PM
t384's Avatar
t384
Brian, did you notice how twisted the splines are in the third photo?
Old Jan 3, 2008 | 02:59 PM
BrianCunningham
Yep,
That's what happened when SloRvette hit the nitrous button.
To Front Wheel bearings
