Anyone use DIACOM software?
Old Nov 29, 2001 | 08:00 PM
90corvette's Avatar
90corvette
Default Re: Anyone use DIACOM software? (Mojo)
Mojo
I am using a home made cable . and yes it looks like the test mode . the cable is a carsten meyers design. and it works with his software on my 90 vette. i have tried it in the ms dos mode and it still dose not work . you say you are using the latest version is that the ecm845 version . i am using a toshiba 4600 wich is a 486 60 mz computer with win 95.
thanks john
Old Nov 29, 2001 | 08:08 PM
90corvette's Avatar
90corvette
Default Re: Anyone use DIACOM software? (90corvette)
Mojo
part 2 of my answer the only parameter that i changed on the defaults was to the 730 ecm should i do more
john
Old Nov 29, 2001 | 09:53 PM
drive it's Avatar
drive it
I'm not sure on Craig's scan software as I'm using Diacom, but a thought that might help? If your cable is to the parallel port? I found on diacom that I had to change the mode to ecp/epp before it would link and even though it's lpt1 I had to change diacom to link with lpt2. A quirk of diacom with my laptop that may or may not help?
Old Nov 30, 2001 | 01:09 AM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Re: Anyone use DIACOM software? (pfast89)
Mr. Mojo:
$99 for the cable and I can download de demo, If I want the program and the cable is for $190, ok.
In the craig´s moates´ software says, for 87-89 TPI, What about my 91 ?
[Modified by Eduardo L98 1991, 11:12 PM 11/29/2001]
Old Nov 30, 2001 | 06:57 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
Default Re: Anyone use DIACOM software? (Eduardo L98 1991)
If you want something like the Diacom scanner for a whole lot less check out Ease OBD1 or OBD2 Scan Tools at: Ease Simulations http://www.easesim.com
Ease makes a scan tool for both OBD1 and OBD2 GM versions. You can even get a version that runs on a Palm.
The Personal OBD1 tool is $315 and the OBD2 tool is $350. It includes all necessary cables, software, 1 year of TOLL FREE technical support (and they do answer email and the phone), as well as a 30 day money back guarantee. The Personal version will record hours
of scan data for playback and will play back in graphing (chart) mode using up to 6 charts at the same time. You can also create custom sets of parameters for different vehicles. Ease scan records can be emailed to another Ease user and replayed on their computer so others can help tune or troubleshoot. The OBD1 tool works with ALL GM OBD1 vehicles and the OBD2 version works with ALL GM OBD2 vehicles. They have tools for F*ord and Mopar also.
I rep for Ease and will be glad to email screen clips from use of the tool on my own OBD1 88 vette. If someone orders through me I will get them a 10% rebate of the purchase price. Feel free to email me directly with any questions not answered on the Ease web site.
Mike
mike_88Z51@yahoo.com
Old Nov 30, 2001 | 07:14 AM
Klaus's Avatar
Klaus
Default Re: Anyone use DIACOM software? (Mike_88Z51)
When using such an intrument or software, how do you get the knowhow to deal with and interpret these data?
Somebody mentioned books about TPI :confused: ...
Are there books available to learn about OBD?? for a none ECM expert?
Can you give recommendations?
Thanx,
Klaus
Old Nov 30, 2001 | 12:07 PM
Mojo's Avatar
Mojo
Eduardo,
Craig's software has been updated to include '730 mode for the 90-91 L98's. That would mean $99 for the cable, software for free. If you want better software, the cable does ship with the demo version of TTS. You'll have 20 runs on it before the demo expires. At that point, just register if you want to continue using for $90.
John,
I'm not sure about the Carsten cable, I'd ask the people at www.thirdgen.org in the DIY Prom area.
Old Nov 30, 2001 | 12:46 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
I am using the latest version of Craig Moates software with an AKM cable that I assembled myself. Total cost $35.00! It works fine on the 1990 and sholuld be OK on a 1991. More info than I will ever need!
To get Craig's program to work on my 1990 I had to use a Windows 95 start up disk to boot the computer. The program would not connect using the DOS mode of Windows ME. The laptop in use is a 700 Mhz Compaq Armada 110.
To check out the operaton of the interface cable there is a link through the AKM website that can be downloaded. It will run diagnostics and check it out. http://www.akmcables.com http://www.ttspowersystems.com
[Modified by Wildride, 11:07 AM 11/30/2001]
[Modified by Wildride, 4:15 PM 11/30/2001]
Old Nov 30, 2001 | 02:42 PM
Mike_88Z51's Avatar
Mike_88Z51
Default Re: Anyone use DIACOM software? (Klaus)
Klaus,
An excellent book I found is "How to Tune and Modify Chevrolet Fuel Injection" by Ben Watson. It is available at most of the major book megastores like Barnes & Noble, and through Amazon.com. It costs $16.95 and covers everything from the basic circuit through Fuel Maps , Open Loop, Closed Loop, on through BLM (Block Learn Multiplier). For me it was one of the best investments I have made for my vette. Watson starts at the very beginning and works up. Great for beginners and Pros alike.
Old Nov 30, 2001 | 02:51 PM
Mojo's Avatar
Mojo
I learned a lot about prom tuning from the DIY-EFI mailing list, and this is a great prom tuning introduction.
Old Dec 2, 2001 | 07:33 PM
Klaus's Avatar
Klaus
Thank you Mike and Mojo,
that'll give me good start, I'm going to find out where to get the book. Maybe I'll look into scanning tools thing... :).
Like your homepage Mojo :cool:
Save the wave, Klaus
