L98 advice
Old Jan 5, 2008 | 11:30 PM
Frank-in-San-Diego's Avatar
Frank-in-San-Diego
Default L98 advice
I have a 1987 with a blown motor. I want to rebild or replace this motor. What modifications or upgrades should I be looking for?? I want to use the L98, I would like to spend under $2000 on this. The dealer has a stock long box for $1500. What cha think??
Old Jan 5, 2008 | 11:32 PM
cv67's Avatar
cv67
St. Jude Donor '05
If its a GM long block for 1500??Cant beat that. Which one is it though, they make a bunch of em.
Old Jan 5, 2008 | 11:34 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default 87
I have an 89. I put a gm crate motor in mine. I love it. When rebuilding, remember we have smog ****'s here in california.
Old Jan 6, 2008 | 12:10 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I'd check on that engine, I doubt it has aluminum heads and roller cam. It's probably a Mexican block with a two piece rear main seal.
Old Jan 6, 2008 | 12:23 AM
black88z51's Avatar
black88z51
I had my L98 rebuilt for $1200. and it works fine.
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default blown
when you say blown, do you mean it threw a rod? or some other malady?
Old Jan 6, 2008 | 04:15 AM
Danspeed1's Avatar
Danspeed1
Hard to really say without a proper diagnosis. Engines are the sort of thing you usually set out to only spend a little on.... and then $5500 later you are still wondering why your *ss is sore.
If you threw a rod, you might be able to have the block cleaned, punched out, and rebuilt for around $1300 if you look hard. You can get some pretty good prices on some 355 kits if you look around online. I doubt the long block assembly you are looking at is for a vette. More than likely its a truck 350 with iron heads.
DG
Old Jan 6, 2008 | 09:03 AM
hexane's Avatar
hexane
I have just that on my 383. Holds up well!!! I got a whole motor from a junk yard for $200 as long as I pulled it myself.
Old Jan 6, 2008 | 11:05 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I don't think you can do it for anywhere near $2000.
Old Jan 6, 2008 | 11:06 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Old Jan 6, 2008 | 11:34 AM
Frank-in-San-Diego
I called chevy, and they told me the L98 is obsolete, but they had 4 of them. They told me they are long blocks and they rate at 190 HP. I did not ask for a block casting number or where it was made. I assume it is a roller cam engine and suitable to be dropped in. This is all verbal - My understanding may be wrong
Old Jan 6, 2008 | 11:37 AM
Frank-in-San-Diego
Blown - I bought the car with a "blown" motor. I dropped the pan and there are metal shavings that look like bearing metal. There are a couple of larger parts that look like a piston skirt tab. The motor turns, It does not start. From the bottom, the pistons appear to be intact and no rod failures. I was told it lost oil pressure and siezed, but it is not siezed now. I was also told it was a smoker. I think it is likely rebuildable.
Old Jan 6, 2008 | 11:39 AM
Frank-in-San-Diego
What exactly did you buy? Where and how much was it? If you are happy and the price is reasonable, I would rather copy you than learn from my own experience
Old Jan 6, 2008 | 11:41 AM
856SPEED's Avatar
856SPEED
I spent good money on my L98, but I did it a few years back when crate engines offered modest horse power gains with marginal parts. I decided to hand pick my parts and have an engine builder (a very reputable race engine builder) do all of the machine work and assembly of my orginal block and crank, TPIS/AFR alum. heads, ZZ9 roller cam, with retro fit roller valve train and double roller timing set; bore .030 over and since L98's come with 2 bolt mains, they studded the mains with ARP fasteners, with the whole rotating assembly balanced and blueprinted; I spent a good amount of money on my engine build, but my 355 is now putting down around 360rwhp and I am very happy, but I paid for it.
Having said that, if I was to do it over again today, I would look at a GM 383 crate engine with and get a warranty. If you are looking to spend only a couple thousand dollars it will be hard to make any serious hp gains unless you do the work yourself. But I would do it right the first time, bite the bullet and spend the dollars (if you can) so you don't end up redoing everything later on.
Old Jan 6, 2008 | 11:47 AM
Red Tornado's Avatar
Red Tornado
1. lift the radiator cap.
2. R&R with a 502cid crate motor
3. replace the radiator cap.
Old Jan 6, 2008 | 11:50 AM
zr1fred's Avatar
zr1fred
You might try a wreaking yard if you just want to get the car running. They should be from $800-$1500, usually with a 3-6mo warrantee. If you pull the engine down, you may get by with just a crank kit and rings. You need to figure out how much you want to be in this car for and what you are planning to do with it. It's easy to get buried real quick.
Old Jan 6, 2008 | 12:48 PM
clevette's Avatar
clevette
L98 for 1500!! Pace has short blocks for 900..
To L98 advice
Old Jan 6, 2008 | 01:15 PM
Iroc57's Avatar
Iroc57
Old Jan 6, 2008 | 01:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Im wondering if that 190hp motor isnt the old "Goodwrench/Target" 350. I believe they were flat tappet motors.
If you want a stock basic rebuild you may still find a local place who could probably do a basic rebuild/go through the heads for what youre looking to spend. Wont be anything fancy but neither was stock but I imagine it will get you down the road fine. I understand not everyone is looking for a racer.
Old Jan 7, 2008 | 04:19 AM
Danspeed1's Avatar
Danspeed1
I was thinking the exact same thing; you beat me to it. That 190HP motor sounds like the GM Goodwrench 350. A while back (but no longer from what I can tell) Scoggin-Dickey offered that engine, and the price was no more than $1100 for a long block with valve covers. That is not the worst direction you could go in if your looking for something NEW and cheap. That's a pretty stout engine. When we purchased our C3 about 6 years ago,... not knowing any better at the time, the engine that was originally in there (we believed to be a race engine) was swapped out and the pretty much put the cheapest engine they could find in the car (being that one) and than sold the car to us. We did some research back then; if you GOOGLE you should find numerous articles on that engine, I think hot rod, super chevy, and a few others did some neat articles on that engine,... low buck modds, big power.
Anyway, that motor was perfect candidate for a 144 Blower; low compression, 4 bolt mains. And thats exactly what we did. Made alot of power for a good 4 years, until dear old dad over revved it one day racing a buddy, and damaged the valve springs.
Since than we got rid of the blower and stroked that same GM Goodwrench block out to 377ci.... its still in the car today.
DG
