1984 leaning problem
Old Jan 6, 2008 | 03:46 PM
stick105's Avatar
stick105
Default 1984 leaning problem
I noticed today that my 1984 leans about 1 in in the drivers side nose. Meaning that the measurement from the ground to the highest part in the arc of the front wheel well is about 1 inch different from the drivers side and passengers side. drivers side is lower 1 inch. could bad shocks cause this? Yes I am a fat guy and no I was not sitting in it at the time.
Old Jan 6, 2008 | 06:34 PM
94z07fx3's Avatar
94z07fx3
Assuming that your car has the original setup and not coil overs, shocks can not affect ride height. So no. Bad shocks can't cause one side to be lower than the other.
There is a single spring for the front of the car. This spring is what holds the car up. It is transversly mounted and made of space age good stuff. They do wear out and they can be replaced.
Is it possible that a PO installed a lowering kit? If so, then I'd check to make sure that the spacers were the same on both sides.
Old Jan 6, 2008 | 08:30 PM
stick105's Avatar
stick105
that is what I am saying. one side (drivers) is 1 inch lower than the other (passenger).
Old Jan 6, 2008 | 08:34 PM
stick105's Avatar
stick105
Also, only the drivers front is different in height. the rear (both sides) are equal in height. Just the drivers side front is lower than the passenger side.
Old Jan 6, 2008 | 08:38 PM
stick105's Avatar
stick105
also, no coil overs. looks like old maybe original shocks. I doubt someone installed a lowering kit on just one axle.
Old Jan 6, 2008 | 09:19 PM
the blur's Avatar
the blur
there all like that.
I brought an adjustable bolt kit.
Old Jan 7, 2008 | 12:20 AM
stick105's Avatar
stick105
Thanks Blurr. What kind of bolt kit?
Old Jan 7, 2008 | 08:50 AM
enventr's Avatar
enventr
For some reason ever since I replaced my shocks in my 95 vert, the ride height is slightly higher than before replacement. I used KYB shocks. The shocks are in about 4 months. They should have settled by now
To 1984 leaning problem
