fusible link
Old Jan 6, 2008 | 10:20 PM
bobby hill's Avatar
bobby hill
Default fusible link
What is in order to change the fusible link? I was driving and the starter wires were on the header and heated up. The car died on me , once the wires cooled backed down it started back up. The car will always start and run but eventually dies after a few minutes of running. Im trying to sell the car right now and need a little help. thanks
Old Jan 6, 2008 | 10:23 PM
KeyWestJack's Avatar
KeyWestJack
Old Jan 6, 2008 | 10:40 PM
LarryK 87's Avatar
LarryK 87
doesnt sound like any issue with a fusable link to me, a fusable link is not much more that a thinner gauge wire placed in line with a larger gauge wire, it is designed to burn away under a heavy load, just like a regular fuse, and like a regular fuse, is a one shot deal, blowen is blowen
Old Jan 6, 2008 | 10:43 PM
RRT vette's Avatar
RRT vette
Yeah, sounds like you need to replace and reroute the "wires" that grounded on the exhaust
Old Jan 6, 2008 | 10:48 PM
dukecebrelli's Avatar
dukecebrelli
...Blow up... blew up... blown....
OK, anyway, Is your check engine light on?
Make sure all your wires are tight- I had a problem similar and I spent a week testing every single one of those fuseable links and it turned out a nut on the power distribution block behind the battery was loose... Do you have to wait at all to start it back up?
Old Jan 7, 2008 | 12:30 PM
bobby hill's Avatar
bobby hill
I dont have to wait at all unless the car was running and its hot. And no the check engine light isnt on. I would like to fix this quickly as someone is very intereseted in the car.
Old Jan 7, 2008 | 06:52 PM
dukecebrelli
...is this an overheating issue?
Old Jan 7, 2008 | 07:28 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
On the later cars, be sure to check behind the battery.
If they go back there, it could start a big fire!
My battery was slightly melted
Make sure you use the some size & length link for a replacement, and the connection is good.
Old Jan 7, 2008 | 07:38 PM
RRT vette's Avatar
RRT vette
If you looking to replace one. I believe NAPA usually has these in stock. I would take one in with you so they can measure. Here is a pic.
Old Jan 7, 2008 | 07:50 PM
Demonic85's Avatar
Demonic85
NAPA has them in stock in all different sizes. If its an inline fusible link you'll have to cut out the old one and solder the new one in. I had one near the starter burn up on mine.
Old Jan 8, 2008 | 01:51 PM
KeyWestJack
This might be of interest.
http://www.hotrodders.com/forum/fusi...t=fusible+link
http://www.hotrodders.com/forum/anot...t=fusible+link
http://www.fusiblelink.net/
http://youtube.com/watch?v=Xi1LU45Nip0
To fusible link
