Sunvisor Mounting Clips
Old Jan 8, 2008 | 10:08 AM
skybolt31's Avatar
skybolt31
Default Sunvisor Mounting Clips
I removed the sunvisors on my 86 when I did the weatherstripping and now I am replacing them. When I took them out, there was a little clip at the top that I ended up destroying when I took them out, the Dealer wants $6 each for replacements. Is there something I can use as a substitute for this??
thank, Bruce
Old Jan 8, 2008 | 12:43 PM
C4boy's Avatar
C4boy
Do you mean these push nuts?
You can probably find them at a hardware store that has nuts & bolt bins. Or drop me your address and I'll mail you a few. I bought a bunch when I pulled mine apart.
Old Jan 8, 2008 | 01:08 PM
rich653's Avatar
rich653
if you have a tap & die set you can cut some threads in the post that the spring goes over and use a small nut to secure, I did that to mine and it worked good but I can't remember what size I used I'm thinking it was 8/32 nc. I had tried the push washers from home depot but they kept popping off.
Old Jan 8, 2008 | 10:11 PM
skybolt31's Avatar
skybolt31
Thanks guys, I will see if I have some push nuts on hand, otherwise, C4boy, I may take you up on that offer.
Old Jan 12, 2008 | 02:30 PM
skybolt31's Avatar
skybolt31
I got some rectangular shaped push nuts from the hardware store for 35 cents that seem to be doing the trick, didn't need to go to plan B (thread cutting) well so far anyway............
thanks for the help
To Sunvisor Mounting Clips
