Couple of hard start problem
Old Jan 11, 2008 | 04:23 PM
Bob88Convertible's Avatar
Bob88Convertible
Default Couple of hard start problem
Just got my motor back together after fixing a valve problem. But now when the motor is cold its hard to start. I have to turn it over a couple times, stop give it some gas, turn over again, repeat this three or four times before it will start. After the first time you start it and warm up the engine it starts right up no problem. I have all new fuel injectors and I can hear my fuel pump run when I initially turn the key on. Fuel pressure is 47 psi. All my mods are in my signature.
The other problem on startup is a surging idle, goes back and forth from 900-12 or 1300 for 15 or 20 seconds. Its like its searching for the right idle speed. After 15 or 20 seconds the idle settles down and it is ok until I start the car again. It does this even when I start the car when it is warm, although only for a few seconds.
Any ideas??? Thanks in advance.
Old Jan 11, 2008 | 07:23 PM
dukecebrelli's Avatar
dukecebrelli
Mine starts fine, but I have the same idle problem- cold or warm...
Old Jan 11, 2008 | 08:49 PM
RRT vette's Avatar
RRT vette
Sound like you have a problem with the cold start valve system and a vacuum leak.
Old Jan 11, 2008 | 08:55 PM
Johns87's Avatar
Johns87
The surging sure sounds like a vacume leak.
Spray carb cleaner or starting fluid around all the places a vacume leak can occur(hoese and gaskets etc.) with the engine running. If/when the engine surges, you found it.
Take Care, -John
Old Jan 11, 2008 | 08:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check your min. idle/TPS and then start looking for vacuum leaks.
Old Jan 12, 2008 | 09:42 PM
Bob88Convertible
If it was a vacuum leak, why would it stop after a few seconds.
Old Jan 12, 2008 | 10:59 PM
AGENT 86's Avatar
AGENT 86
IAC will compensate trying to achieve target RPM. Once it's(ECM) figured out how much to close pintle, idle will settle down.(as long as it's not a huge vacuum leak.)
Just pointing out possibilities.
Old Jan 12, 2008 | 11:06 PM
RRT vette's Avatar
RRT vette
I agree with AGENT 86. Have you tried to pull codes?
Neither the CSV system or a vacuum leak will cause a code.
Old Jan 13, 2008 | 10:31 AM
Bob88Convertible
Reset the idle, set the tps voltgage and that seemed to help a little. Stiill get some surging on startup that goes away in 20-30 sec. I checked everywhere I could think of for a vacuum leak, intake, runners to intake runners to plenum, plenum cover, vacuum lines. Any ideas on where else I should look for a leak. Thing runs great once the surging stops, but its a real pita because it does it every time you start, hot or cold.
Haven't had a check engine light, so no codes.
Thanks for the help guys.
Old Jan 14, 2008 | 09:44 AM
Bob88Convertible
Found a vacuum line unplugged. There's a little junction box (for lack of a better description) bolted to the thermostat housing. It has four vacuum lines and a small electrical plug on top of it. One of those lines was disconnected. Only way I could get the line back on it, was to remove the junction box from the thermostat housing and pull it out from under the plenum. I got all the lines reconnected, but still have the surging problem. Does that metal bracket with the vacuum lines and the electrical connection have to be grounded? Is that why it was bolted to the thermostat housing?
Old Jan 14, 2008 | 09:52 AM
AGENT 86's Avatar
AGENT 86
That's the EGR solenoid and no, it doesn't need to be grounded. Now that you found a vacuum leak, maybe another min idle/TPS adjustment is needed.
http://members.shaw.ca/corvette86/EGR%20System.pdf
Old Jan 14, 2008 | 10:14 AM
RRT vette's Avatar
RRT vette
Yeah, that is the EGR solenoid. It should have three vacuum "looking" lines on it. I know there are differences in year models with vacuum lines. My 86 has one vac port under the throttle body that runs to one side of the solenoid. On that same side, one vac line runs from the solenoid to the EGR. The opposite side of the solenoind has one vac line that doesn't go to anything. I believe there was some type of filter on the end of it from the factory. Seems like I remember someone saying there were two vacuum ports on some of the later throttle bodys.
I would ground the ALDL and see if any code is there anyway. If no codes, you will need to check things that don't cause codes.
To Couple of hard start problem
