Best high-temp engine paint?
Old Jan 12, 2008 | 12:58 AM
MarkBychowski's Avatar
MarkBychowski
Default Best high-temp engine paint?
Hi everyone,
I need to repaint an oil pan (black) and want to use something that will hold up to the heat as well as fluids. Anyone use a specific brand with good results? (I already did a search and didn't find anything)
Thanks!
Old Jan 12, 2008 | 01:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
I a rattle can had good luck with VHT. There are a bunch on the market today.
If you dont mind some prep work the POR-15 makes some kickazz engine paints, it will never fade, chip, nothing. Looks new 5 years after applying.
Old Jan 12, 2008 | 02:35 AM
No Go's Avatar
No Go
I'm with above...I've used on blocks and they both look marvelous...several years later.
Cheers!
Old Jan 12, 2008 | 10:04 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I used VHT caliper paint for the whole bottom end. My calipers still look good after 5 years, using the same paint.
Old Jan 14, 2008 | 02:38 PM
MarkBychowski
Thanks much, guys -- VHT it is!
Old Jan 14, 2008 | 04:21 PM
bczee's Avatar
bczee
As with anything. good clean prep work is a must..
Old Jan 14, 2008 | 05:55 PM
waveman22's Avatar
waveman22
Default Mercury marine!!!!
Mercury Marine boat outdrive paint is AWESOME. I use it on all motors. It
even survived the hot vat on several blocks and looks great too.
Waveman
To Best high-temp engine paint?
