Can someone ID this part?
Old Jan 12, 2008 | 03:07 PM
Vette Gator's Avatar
Vette Gator
Default Can someone ID this part?
While tightening the thermostat housing bolts, I had to take the electrical connection (two wires) off this part. It looks like it's supposed to have vacuum lines connected as well, but I didn't find any hoses laying around that might correspond. The part is on a bracket that sits under the back thermostat housing bolt, but it doesn't seem to be connected to anything else as far as I can see.
What is this part, and what are the consequences of not having its hoses disconnected? The car seems to be running fine with no check engine light or codes as far as I can tell.
Old Jan 12, 2008 | 03:16 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
This sits by the thermostat and vacuum lines attach to it. I am not quite sure what it does.
Old Jan 12, 2008 | 03:25 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would assume it's the EGR solenoid. Should have a vac line from TB and EGR diaphragm.
Old Jan 12, 2008 | 03:27 PM
jsup's Avatar
jsup
So no EGR, no need for the solinoid.
I was just going to look this up in the FSM for my own reasons.
I don't have time now, I'll look it up later.
Aardwolf's Avatar
Aardwolf
Looks like vacuum part for EGR.
Old Jan 12, 2008 | 04:43 PM
staugur's Avatar
staugur
It is the egr vacuum solenoid.Do you have an egr valve?If so this should be connected.If not the egr inlet should have a blank plate on it.If it's not gone already you can also remove the egr pipe from the exhaust to the manifold and the temp sensor.And the air pump along with the cats 'cause by now your not going to pass emissions if you have them.Oh and the air injection pipes on the top of each manifold can go as well.Cleans it up pretty good.
Old Jan 12, 2008 | 10:15 PM
jsup's Avatar
jsup
I guess this fitting can be removed then and capped.
FWIW, passing emissions without an EGR in many states is possible with a good tune. Just don't let the car idle for a long time before going to inspection.
Old Jan 13, 2008 | 12:17 AM
Vette Gator
Thanks for the quick answers. I will check tomorrow and see what's there for the EGR system. As far as I knew, the motor is stock, but maybe that's not the case.
Old Jan 13, 2008 | 12:36 AM
86PACER's Avatar
86PACER
EGR solenoid.
One of the ports (the left one) connects via a hard vacuum line to the bottom of the TB. Check the small vacuum port on the bottom of your TB. This is the EGR valve's vacuum source. The other port goes directly to the EGR valve itself, which is mounted on the intake base below the plenum.
Old Jan 13, 2008 | 08:29 AM
jsup's Avatar
jsup
Originally Posted by 86PACER
EGR solenoid.
So I can remove this and cap the vacuum line on the throttle body since I have no EGR.
What is the electrical connection?
I know I know, look in the FSM......I'm just that lazy/busy. It's supposed to snow later so I'll be trapped in the house, I'll look then.
Old Jan 13, 2008 | 09:56 AM
AGENT 86's Avatar
AGENT 86
Yes, cap the TB port and tape/hide the wires, the rest can go bye bye.
Old Jan 13, 2008 | 11:33 AM
KENS80V's Avatar
KENS80V
That vacuum source on the bottom of the throttle body also feeds the charcoal cannister. Is this also removed? It is used to time when the throttle body draws the vapors in from the cannister thru the large tube connected to the passenger side of the throttle body.
Old Jan 13, 2008 | 12:48 PM
AGENT 86's Avatar
AGENT 86
Good point, on my 86 it only feeds EGR, later years got the canister in the same circuit.
Old Jan 13, 2008 | 02:32 PM
jhammons01's Avatar
jhammons01
I was thinking that you (the OP) connected the hose that goes to the EGR solenoid straight to the EGR valve and that is why it appears that you aren't missing anything.
But Agent 86s diagram makes it appear too far away to do this without you noticing.
Can anyone verify if my theory is plausible?
Old Jan 13, 2008 | 02:58 PM
86PACER's Avatar
86PACER
OP already said his EGR had been removed.
Old Jan 13, 2008 | 03:53 PM
jhammons01's Avatar
jhammons01
^^then he would have to have that whole loop deleted and the T going to the EGR Loop completely gone.......then that line goes straight to that item identified as a "Fitting" on A86s diagram.
I don't really know, I am just guessing on how a complete vacuum line is not hooked up and nothing is hanging loose.
Old Jan 13, 2008 | 04:16 PM
AGENT 86's Avatar
AGENT 86
I think your confusing the OP as jsup, Vette Gator says he believes his motor is stock.
To Can someone ID this part?
Old Jan 13, 2008 | 04:17 PM
86PACER's Avatar
86PACER
Damn you're right.
Old Jan 13, 2008 | 07:38 PM
jsup's Avatar
jsup
Thanks for the diagram. I have been busy and STILL haven't opened up the FSM.
That's what I have. It feeds the canister. I looked at it physically and it looks as if I can just eliminate the solenoid connections and cap it, keeping the canister hooked up.
Thanks.
Old Jan 13, 2008 | 09:46 PM
KENS80V's Avatar
KENS80V
You must change to a vented gas cap if you do this. I would leave it hooked up as your garage might have a slight gas smell if using a vented gas cap. There is no performance improvement in eliminating the charcoal cannister.
