Suggestion
Old Jan 13, 2008 | 02:46 PM
IceDazzlr's Avatar
IceDazzlr
Default Suggestion
I am having a problem getting my A/C to turn on. I do not see the compressor running at all when I turn on the A/C. I checked every one of the fuses in all three fuse banks on my 1994 Vette and they are fine. The A/C Compressor just will not engage. I am concerned because now both of my cooling fans are not comming on. Are these fans controlled by the A/C. Does anynbody know if low freon can cause the comrpessor not kick in?
Old Jan 13, 2008 | 06:16 PM
comp's Avatar
comp
low charge can keep it from working,,,,, have if jumped the low pressure switch
Old Jan 13, 2008 | 07:57 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Ac
Your freon level is low. When you recharge the compressor will start kicking on again. Look at AC system where hoses are connceted. Sometimes they work loose. If their is a dirty residue around fittings that could be a sign of a small leak.
To Suggestion
