Cold idle issue....
Old Jan 14, 2008 | 01:28 PM
silver86's Avatar
silver86
Default Cold idle issue....
Well, here's what I've got:
1986 supercharged, cammed, AFR 195's, runners, intake, ported plenum, the works.
Here's my issue:
The car cranks, and fires fine. In open loop, I have difficulty keeping it running without forcing the idle up with the throttle. Once closed loop is attained, no more idle issues. I have reset my idle numerous times in attempt to find a sweet spot (I had it once, but I had to do some electrical work, and disconntected the battery, and it hasn't worked correctly since [I can't remember what other work I did at the time which may have contributed]).
I'm going to smoke the intake later to check for vacuum leaks (idles at about 17-18" of vacuum).
I'm thinking the heating element in my O2 might have dumped (heated O2 for the long tubes), or the power/ground wire has been interrupted at some point.
Just checking to see if this scenario is a viable cause for what I'm experiencing.
TIA
Old Jan 14, 2008 | 01:48 PM
redrose's Avatar
redrose
most likely needs more fuel in open loop (very, very vague possibilty that it's too rich, which also will not idle).
Old Jan 14, 2008 | 01:50 PM
silver86's Avatar
silver86
Originally Posted by redrose
most likely needs more fuel in open loop (very, very vague possibilty that it's too rich, which also not idle).
Interesting that you brought that up. The A/F guauge measures very lean in open loop. I never put the two together since I was focused on the O2. Looks like I'm in need of new programming, I guess.
To Cold idle issue....
