Guys
anyone have this problem - changed out the opti on my 1993 and it runs absolutely great....then the Check engine light comes on with code 36....but it runs better than ever! I clear the codes but the light comes back on! Any suggestions?
well looks like I got lucky and ended-up with a BAD OPTI - it runs a bit then just quits, starts righ up and runs for a while then just stops...
well at least replacing it again should not take as long.....
thanks for the suggestions
