Help w/ 84 rear mono spring
Old Jan 17, 2008 | 05:59 PM
mbsoak's Avatar
mbsoak
Default Help w/ 84 rear mono spring
I think my rear mono spring has fatigue, Isw there anyone here w/ a spring out that can measure a spring setting on its ends arch up , measure from center of spring to horizontal surface spring is setting on. I know these springs are tough and I have called several suppliers asking the same question and they don"t have time.I am getting ready to reinstall and if I need new now is time.Before removal when car was jacked up ,no pressure on support bolt, a 2" space. I have tried search method -no luck Thank You Craig
Old Jan 17, 2008 | 07:21 PM
MIke350's Avatar
MIke350
I always thought that when these springs went bad they would crack, splinter, break or completely fail and that they were not supposed to deform and fatigue like a steel one would.
Old Jan 17, 2008 | 09:07 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Usually they do crack, but I have seen them fatique. There are several rear springs for the C4, so you can't really go by arc. Bad shocks will affect ride height also.
Old Jan 17, 2008 | 09:26 PM
aminnich's Avatar
aminnich
Try Jason at vette2vette.com (good guy and supporting vendor).
To Help w/ 84 rear mono spring
