AC Compressor Mounting clearance...
Old Jan 17, 2008 | 10:11 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default AC Compressor Mounting clearance...
1990 L98
I had to get taller valve covers to fit the new rockers I had.
The AC compressor is very close to the valve covers since they are slightly taller.
Think I can put two SMALL washers between the compressor and the bracket to set it off a little?
The bolts are 8MM, about 5/16. So that's the size of the washers I'd use
I don't think it will do anything to the bracket or create any additional stress.
Opinions?
Old Jan 17, 2008 | 11:26 PM
Dads90's Avatar
Dads90
Is it close to the AC itself or the AC bracket ? I notched out the AC bracket to allow for clearance of valve covers for removal. If the washers make it work, just make sure there tight, maybe put some loktite on the threads.
Old Jan 18, 2008 | 07:52 AM
jsup's Avatar
jsup
The compressor itself, the bracket is fine.
The washers would go between the compressor and the bracket to move the compressor out a little.
2 or 3 washers will do the trick.
Old Jan 18, 2008 | 11:38 PM
Dads90's Avatar
Dads90
Go with your plan and just watch the compressor for stability. If it wavers, even slightly, it probably won't hold up.
To AC Compressor Mounting clearance...
