Trick Removable Top graphics!!!!
Old Jan 18, 2008 | 11:42 PM
BlackRocket's Avatar
BlackRocket
Default Trick Removable Top graphics!!!!
A buddy of mine is a graphic artist and does outstanding work!!!! I purchased a used hard top for my Z since mine was missing. The hard top I bought was in "rough" shape. After removing the headliner I discovered the stock headliner is backed by fiberglass packing. Figuring the noise wouldn't be any worse than the plexiglass top and not wanting the annoying sag problem down the road I contacted Dubb for some design work. He came up with the following design!
He professionally repainted the entire exterior using the stock base-coat/clear-coat process in a paint booth, laid on the graphics followed by 2-3 more coats of clear-coat, repainted the metal surround trim and replaced the old weather stripping. Now the top is customized and looks impressive once seated in the vehicle!
He can do hoods, tops and nitrous bottles or whatever else you might want painted.
Prices are reasonable too!
Mild graphics like mine; $300
Wild graphics & complete repainting; $550
New weather stripping; $225
His site is www.dubbdesignz.com or 707-344-6937
