Diff Drain
Old Jan 18, 2008 | 01:55 AM
MaxLean's Avatar
MaxLean
Default Diff Drain
What's the current favored method to add a drain to the D44? I've got it out for a gear swap and want to be able to service it. I'm aware of the 1/8" drain between the pipes and I remember someone talking about intersecting the bottom cover bolt as an option too. Has anyone put a pipe plug in the cover instead? Does anyone have an opinion?
Scott
Old Jan 18, 2008 | 09:45 AM
XQIZT's Avatar
XQIZT
corvette clinic in sanford FL used to offer a "kit"...all it really was, was a template to make sure you drill the hole in the right place...it also had a tap and the right plug...see if they are still open...ask for chris.
and it STILL amazes me that GM didn't put a drain plug on it....come on...REALLY? no one ever believes me when i tell them there is no good way to service it.
Old Jan 18, 2008 | 10:12 AM
Aardwolf's Avatar
Aardwolf
The hand pump method is very easy. I wouldn't spend the time or money to add a drain.
Old Jan 18, 2008 | 10:19 AM
XQIZT's Avatar
XQIZT
...but i wouldn't call that a "good" way to service it...you never really get all the gunk out of the bottom of the diff. i mean, imagine if you had to change the motor oil by hand pumping the old stuff out of the dipstick tube.
Old Jan 18, 2008 | 11:09 AM
vetteset8087's Avatar
vetteset8087
Go to a boat supply place like overtons or your local boat place they should have an electric pump that boaters use to suck the oil up from the dipstick tube they cost around $35. it takes about 10 minutes to suck the grease out of the diff and you can poke around inside the diff to get most of the crap out. Thats what I use. P.S. if it's cold drive it around for 15 or 20 minutes to get the grease warm so it will pump out faster and easier
Old Jan 18, 2008 | 11:13 AM
vetteset8087
heres a link to a pump from Overtons
http://www.overtons.com/modperl/prod...=71741&aID=24A
Old Jan 18, 2008 | 12:33 PM
MislMan's Avatar
MislMan
Since it is off the car, drill and tap in the correct location (not sure where that is) would be best.
I use a siphon pump from Home Depot hooked to a 3/8" drill to drain the fluid. The pump is about hand size and has a chuck end for connection to a drill motor. I installed clear tubing on each end (inlet/outlet) of the pump. You can make the tubing as long as you want to make things easier on yourself while doing this. Put the inlet end of tubing into the fill port and place the outlet tube into a drain pan.
I then use a cheap garden sprayer as a fill device. I modified the outlet tip by cutting off the spray nozzle and installing some clear plastic tubing (also from Home Depot) to the spray wand at the tip. I used zip ties to secure the clear tubing.
Then simply fill the sprayer with the lube of your choice (I use Mobil 1), pump up the sprayer and squeeze the handle. The clear tubing is to allow you to put the tube completely inside the differential and minimize spills. Clear tubing lets you see the fluid flow to ensure things are going OK.
This works good for manual trannys as well.
Later ... Larry S.
Old Jan 18, 2008 | 01:33 PM
Aurora40's Avatar
Aurora40
You realize there are kits designed to do specifically that?
Old Jan 18, 2008 | 02:31 PM
XQIZT's Avatar
XQIZT
of course, but i still say its not the easiest way to do it...its not wrong, but not the best way...all i'm saying is that i would never imagine a tub designer making a bathtub that you had to empty by pumping the used water into the sink would it have killed GM to put a drain plug of the diff?
Old Jan 18, 2008 | 03:02 PM
vetteblack's Avatar
vetteblack
Hey, GM has to look out for there parts division too! People who cant/wont change the fluid are going to need diffs!
Old Jan 18, 2008 | 03:11 PM
ultraviolet70's Avatar
ultraviolet70
I installed the drain plug kit in my diff and am happy with it. The drill bit and tap included have washers welded at specific depths so you don't go to deep and damage your ring gear, but I guess if your doing this on the diff that's disassembled it doesn't matter.
By the way if anyone is interested in this they can have it for a few bucks you just have to locate a drain plug to go with it.
Old Jan 18, 2008 | 09:38 PM
DanZ51's Avatar
DanZ51
I added a drain to my diff years ago when I changed gears. I think I used a drain plug from an old oil pan (magnetic) . Figured a good spot on the cover that cleared the ring gear, then drilled and taped (NPT).
I know NAPA used to sell a kit for AT oil pans.
Trust me, this is alot easier than trying to suck out the old fluid . If you got the cover off there's no reason not to do it!
Old Jan 18, 2008 | 10:29 PM
Ajaste's Avatar
Ajaste
truer words were never spoken
Old Jan 20, 2008 | 08:07 PM
MaxLean's Avatar
MaxLean
Well, thanks for all the advice guys! I ended up drilling and tapping for a 1/4" pipe plug just beneath the ring gear on the meaty part of the case just ahead of the flange. Looks like it'll work pretty well (it's bigger than the 1/8" plug that comes in that kit), but it's right above the left exhaust pipe! I'll have to drop the exhaust slightly to access it, but it's no biggie.
Scott
Old Jan 21, 2008 | 02:45 PM
pmihaltian's Avatar
pmihaltian
Slingshot
To Diff Drain
