My car is a '92, but I think the hood latch cable is the same on all C4s.
I've never had a problem with the cable, but it seems to be getting stiffer.
I bought a new cable to install, and I am wondering if there is anything that can be done to prolong its life.
Which end of the cable usually fails, the part at the hood latches, or the part under the dash by the release handle?
How does it fail, does the cable break or do the ends come loose?
And, has anyone tried to inject lubricant into the cable housing to prolong its use?
Tom Piper
Good question. I think a good visual inspection of the cable system will show where it is wearing. As you probably know, a lot of guys put a standby system on in case the cable fails.
Generally they crack in the engine compartment when they get brittle. Making sure the latches are adjusted and lubricated and the return springs are working is probably the best maitainance. I would think lubricating the cables might cause more problems down the line.
How much do you need to worry about it if they last 16 years at a time? Got my piece of mind by installing emergency release cables that can be reached from the outside as done by many others.
Since mine is getting stiff and I have a new one, I am going to put the new one on.
However, if there is anything that can be done to keep it longer, while it is out is the time to do it.
I do intend to install emergency cables too.
Originally Posted by zr1fred
Generally they crack in the engine compartment when they get brittle.......
That sounds like the plastic housing is the problem and not the cables.
It doesn't seem like there is much that can be done about that.
Tom Piper
On my motorcycle, when I serviced the carbs, I took the throttle and choke cables loose and hung them up. I sprayed white lithium grease down the inside of the covers and left them hanging for a couple of days while I worked on the bike. Since then, the choke that was so stiff I had to hold it in place to engage it moves freely and rests where I leave it. I would pull the cables on your new set as far out of the cover as you can and coat them with the WLG then do the same for the other end. WLG doesn't drip and generally stays where you put it.
(Yeah I know my bike (CV carbs) doesn't have a choke but rather a "enriching circuits" but the control is labeled "Choke")
thats what i do on harleys...except i hag em and use tranny fluid n small funnel ...pour small amount n let it run thru into catch can...amazing difference in ease of operation
