Electrical Problem...
Old Jan 19, 2008 | 07:05 PM
TRace8893's Avatar
TRace8893
Default Electrical Problem...
I have a 1993 coupe. What does the 3 amp diode do in the power seat circuit? (It's on the power seat switch connector in the center console.) Can I do without it? Mine is shorted and I'm having some trouble finding one in my area to replace it.
Old Jan 20, 2008 | 12:23 AM
jfb's Avatar
jfb
I think any 3 amp 400v or higher silicon diode will replace your shorted one. Available at Radio Shack, part number 276-1144, $1.59 .
Old Jan 20, 2008 | 12:01 PM
Tom Piper's Avatar
Tom Piper
Originally Posted by TRace8893
.....What does the 3 amp diode do in the power seat circuit? ........
The short answer:
The diode absorbs unwanted voltage transients caused when the motor (an inductor) runs and is shut off.
The long answer:
When any inductor (including a motor) is energized, a magnetic field builds up around the coil (the motor winding).
When the power is shut off to the inductor (in this case, the motor), the magnetic field will collapse inducing a voltage into the inductor.
The purpose of the diode is to absorb that voltage (electrical noise) and prevent it from getting back into the main power supply (in this case, the battery).
It probably prevents you from hearing a "click" in the radio when the power seat is energized and turned off.
Normally, you will find a diode across the A/C compressor clutch windings for the same reason.
Tom Piper
Old Jan 20, 2008 | 06:01 PM
RACER 1993's Avatar
RACER 1993
Default Diodes
If you have the Factory service manuals, under intermittent problems you will see that there are a number of diodes in the car. Transients caused by the absence of a diode in a circuit can cause other problems. If you know the diode is bad, I would replace it. You can also get them at places like Newark Electronics.
You have already done the hardest part of the job by taking the console apart.
Old Jan 20, 2008 | 08:27 PM
TRace8893's Avatar
TRace8893
Managed to find a Radioshack 50 miles away that has the 3 amp diode (gotta love living in a small town...). Should have my car together again tomorrow...
My dad was wondering if there was just some way of bypassing the diode. Thanks for the input, guys!
And yes, I know it's shorted out... I hop in my car to head to the college and my car seemed deader than a door nail. Put the jump cables on it and had some sparking and pulled fuses until it was driveable again and tracked it down to the fuse for the power seats and then had to 'hotwire' the seats for further diagnostics.
Old Jan 20, 2008 | 09:37 PM
jfb's Avatar
jfb
A low valued resistor will do pretty much what the diode does, something like a 25 watt 5 ohm resistor, but since you already have the diode, use it!
To Electrical Problem...
