Hybrid intake?
Old Jan 21, 2008 | 07:18 PM
Cyclonite's Avatar
Cyclonite
Default Hybrid intake?
So, with the MR, SR, HSR, et.al, has anyone ever taken something like an Edlebrock Victor (or whatever) and put on some sort of tunnel (homemade or adapted TPI plenum) to make some sort of hybrid TPI replacement?
Just curious if it would even be worth the effort...
Old Jan 21, 2008 | 07:51 PM
Curveit's Avatar
Curveit
Several people on the Forum here run modified single-plane intakes with fabricated Plenums. Edlebrock offers the #29785 and 4 or 5 Elbows have just been introduced. I haven't heard where anyone has tried one yet; or the manifold either. Professional Products has one too, but I'm not familiar with the company... probably Chi nock-off of the Super-Victor.
Old Jan 21, 2008 | 11:28 PM
Deakins's Avatar
Deakins
People run throttle bodies on single plane intakes all the time. It's the best of both worlds; electronic fuel injection reliability on an intake that can support 8000+ rpm on a big inch small block.
Old Jan 22, 2008 | 12:09 AM
bill mcdonald's Avatar
bill mcdonald
I picked up a single plane with 90 degree elbow, off the forum here. I need a highrise hood because the plenum is too tall. or someone to do some work on it.
Callaway sledgehammer had a dual carb intake with what looks like the TPI plenum mounted to it.
Old Jan 22, 2008 | 07:21 AM
mgbss's Avatar
mgbss
I have been looking into this a bit myself looks like great alternative, but I need more info.
Yes the Professional Products are China Knock offs of Edlebrocks intakes.
Edlebrock has the intake and the Elbow like mentioined above, haven't looked at price yet but sure its up there, EFI is like Boats (or Vettes) everything is higher because of it. You can buy a Carb intake for 150 call it EFI and its worth 300+
My .02 cents
Joe
Old Jan 22, 2008 | 05:00 PM
Curveit's Avatar
Curveit
Summit has the intake @ $326...fuel rails are $80 (necessary?) The Elbows are $120(#3847) or the "Box" type (#3850) for $150. The Els require an LS Throttle Body, and I don't know for sure what part combos would fit under a stock hood, but it looks promising. I figure the Bottom-end power would equal a Mini-Ram at least; Mid and Hi range should be better. I think a modified Victor Jr might perform even better than the above manifold, on the street. JMHO
Old Jan 22, 2008 | 06:16 PM
black85vette's Avatar
black85vette
Default hybrid intake
So if it uses the LS-1 T- Body what controls the idle does it have a built in idle air controller? will this connect and work correctly with the stock computer?
Old Jan 22, 2008 | 06:32 PM
AKS Racing's Avatar
AKS Racing
I went the large tube runner, SR, then MRII. Due to issues with varied A/F ratios front to rear (front rich, rear lean) when pushing higher HP levels, I finally exited the MRII. I then went to a C4SP.
I bought the Weiand Team G converted intake used. Had I known then what I know now, I would have fabbed it myself. The unit that I purchased was prone to injectors coming loose from the fuel rail (read as raw fuel spewing all over everything, including hot headers), that nearly cost me my car. And the prev owner had suggested that I "might" want to consider stanchions to support the rails vs the method originally used.
Anywho, much welding and machine work later I now have an intake that works well. A/F ratios are consistant between cylinders, and it clears the factory hood. Once the design was right, it was fully powdercoated and looks quite nice.
Intake before install.
Intake on car
Aaron
Old Jan 22, 2008 | 06:48 PM
black85vette
That turned out good! Is the upper throttle body plenum available? Or is that a one of a kind unit?
Old Jan 22, 2008 | 07:30 PM
Tom 35th anniversary's Avatar
Default Can be used on a 350?
Can this unit be used on a 350, or is it only for use on larger cubes like 383 or larger?
Intake on car
Aaron
Old Jan 22, 2008 | 08:25 PM
AKS Racing's Avatar
AKS Racing
All of the parts were one-off. But, www.intakeelbows.com sells a similar elbow that should clear a stock C4 hood. There are also numerous examples of single plane 4BBL intakes that are readily available with fuel injector bungs cast with the manifold.
With regard to the size of the engine, a smaller displacement engine will obviouly loose some low end power, but there are many cars on this board that have ample low end, and could use a loss of low end (and subsequent increase in top end HP) to improve their cars short times.
Aaron
Old Jan 22, 2008 | 09:15 PM
mgbss's Avatar
mgbss
Aaron
I was looking at your intake the other day while doing a search, looks great.
Is there much science to the Elbow or is it pretty much straight forward? The intake looks to be a single plane is there any pros or cons to a single or a duell plane, for this type of set up. It sure seems to open up quite a few more options for the EFI on our cars.
Joe
Old Jan 22, 2008 | 11:15 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Super victor single plane works for me. Got my best 60" of 1.49 with this setup. I went with the single plane to lose some bottom end, I had a superram, and pick up 1000+rpm on the top end. Turns out the single plane gives me the best of both worlds.
Old Jan 22, 2008 | 11:53 PM
Curveit's Avatar
Curveit
AKS Racing... Been a fan of your set up for a long time. Looks good and looks like it would flow well. Curious as to what you used to fill in the welds and still be able to powder coat?
Old Jan 23, 2008 | 02:24 AM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Nice looking setup!! Kudos for being different and making it work.
Old Jan 23, 2008 | 02:36 AM
USAsOnlyWay's Avatar
USAsOnlyWay
I just wrote a letter to Chevy Hi-Performance about this asking them to do an EFI shoot-off with the modified carb manifolds in the mix. Sure would be nice if they would.
Old Jan 23, 2008 | 06:21 PM
Curveit's Avatar
Curveit
Supposed to...the guys using the "First" intake will have to use the LS or Ford TB, and I recall reading all the stuff is there and will hook-up. I really don't know from experiance. I'm still trying to figure out how to utilize an RPM dual-plane. Intakeelbows said they would do the Injector bungs and fuel rail. The problem is one manifold plenum is about 2 1/2" deeper than the other. Equalizing the plenums and keeping the TB in the stock position, along with keeping everything under the stock hood would be a challenge.
To Hybrid intake?
Old Jan 24, 2008 | 02:50 PM
AKS Racing's Avatar
AKS Racing
I am not really sure what you mean by "fill in the welds". The welds are still visible in most areas, though blasting prior to powder coat does remove alot of the detail. The powdercoat is directly over the blasted aluminum.
And to everyone else, thanks for the compliments.
Aaron
Old Jan 24, 2008 | 03:41 PM
Curveit's Avatar
Curveit
OK... Just good welding. Looks really nice. I've just never heard what could be used to fill welds, and still be able to stand up to powder-coating heat.
Old Jan 24, 2008 | 09:13 PM
chriswtx's Avatar
chriswtx
Here's mine...
started life as this...
