4+3 to ZF6?
Did a search but couldnt figure out what kinda flywheel to use?
Will all the 4+3 parts work?
Read something about the flywheels being different thicknesses so what has to be done or used to make this work?
The 4+3 flywheel is about 3/8" thinner than the ZF6 flywheel.
The ZF6 replacement single-mass flywheels are the same thickness.
Some theories are out there that when swapping to the 4+3 single mass flywheel, the fork angle could cause problems. Centralcoaster performed this swap using the 4+3 flywheel, and the stock ZF6 stud without an issue.
I mocked mine up, and I agree that the stock stud might be a hair too short. It seems as it if compresses the clutches slave cylinder way too much, and as the clutch wears can cause some problems.
Then again, the suggested ZR1 stud adds 5/16" which puts the fork
pretty far away from the slave cyl rod, and only gives you about 5/8" of working area. It also could cause a clearance issue with the pressure plate, although it appears as long as the travel doesn't exceed 5/8" it should be fine. I'm told slave cyl travel is roughly 13MM (or 1/2").
In MY opinion, I think what I will end up with is the ZR1 stud, and then adding a coupling to the slave cylinder rod to get the travel within the normal operating range. I just need someone to measure the compressed distance of the rod in a STOCK OEM ZF6 setup, so I can get an idea of how much length to add to it.
-- Joe
-- Joe
-- Joe
