hi guys,
im getting back my freshly machined block early next week that has been acid bathed,bore and honed and decked ready to fit new engine parts.
i have ordered a engine cover bag for the block,but cause i wont be installing crank,pistons,rods for a while i wanted to ask you what can i spread/rub on block on decks and cylinder bores so they dont rust up ??
can i use grease or vasoline may be??
or engine oil or installtion lube may be??
is there a specilised product for this job ??
i guess it would be good if this product doesnt run of the metal easy and is easy enough to clean when time comes to install parts
any ideas please guys??
thanks
shae
Ive used LPS heavy duty Rust Inhibitor. ..I've got a block in my shed for about a year and it still looks good..It's kinda waxy when it dries but comes right off with that orange degreaser stuff(any brand)...You can get it at Napa I think...
Waz-Up Shae...Havent you got that thing built yet What are ya waitin for ..
hi there all fellas,
cool,thanks all for your replies guys.
much appreciated !!
i never thought about using wd-40,good idea.
i guess i will try that one first,then others later if needed.
r.e what happydad mentioned,yeah im doing bit by bit as im on a budget.
but just about have all the parts and hp parts now to build the beast!
i gotta tell ya though,i cant wait
cheers guys
shae
hi rod,
how are ya.
no mate, i wont be puting it togeather myself.
i mean to say the engine builder.
btw mate, i brought some quality castrol 15w40 diesel oil like you mentioned for the run in procedure.
thanks
shae
I use WD-40 on my blocks. In fact, that's exactly what it was designed for. "Water Displacement" formula 40 was designed specifically to keep moisture off of metal. Always worked well for me, cleans off easily with alcohol for painting later, and I kinda like the smell .
Well WD-40 is a solvent so it would not be my first choice.
Not to mention WD-40 attracts dust and then falls off.
An Engine builder from VW in Wolfsberg years ago showed me what He called "assembly lube" I saw it again from a completely different source when I was tinkering with RX-7s.
Assembly Lube is a 50/50 mixture of Marvels Mystery Oil and STP oil treatment. You get an old style oil can....the one that has a spout and thumb trigger.......and you mix them in there and squirt a healthy amount on surfaces that may rust and especially surfaces that have parts that contact each other.
50/50 mix of Valvoline 10w-30 and STP is what I use for assembly lube. I coat the bearing surfaces, pistons, cam, etc during assembly. For the outside of the block, however, I think it would be pretty difficult to clean off for paint. STP is some pretty sticky stuff...
and further thinking, wouldn't now be the time one would/should be applying engine paint to the external areas of the Block?
Masking any mating surfaces as well as any holes.....then blasting it with a high temp engine paint would be my first choice for preserving the outside areas of the block.
