ZF6 clutch fluid (HELP!)
Old Dec 1, 2001 | 10:55 AM
95vett's Avatar
95vett
Default ZF6 clutch fluid (HELP!)
What fluid do I use in the Hyd clutch resevior? Is it Dot3 brake fluid?
Thanks in advance
Also what is the easiest way to get the PCM out of the way to add fluid
I understand I will probably need to replace/rebuild the master/slave cylinder soon what are the costs/time involved with this.
Old Dec 1, 2001 | 11:53 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: ZF6 clutch fluid (95vett)
Best bet is to use GM hydrolic clutch fluid. DOT 3 brake fluid will work fine but may develop a squeak that bothers some folks, the GM stuff has an additive to prevent the squeak.
