L98 Cracked Heads
Old Jan 30, 2008 | 01:28 AM
bdaum2112's Avatar
bdaum2112
Default L98 Cracked Heads
I purchased a 87 coupe with motor problems in December. I have just got around to tearing it down to discover both heads are cracked. I have heard that they can be welded. is this worth it or should I invest in a set of performance heads. I would like to boost the HP to around 300. I had a 93 that was stolen and a 94 that I traded in on a wife and 2 1/2 kids (one step child) and like the power that the LT1 had. What would be the cheapest way to get to 300hp. I figured that heads would be the first step since they are cracked any way. I am wondering if i should just get it running or wait till i a had some more cash saved to up grade?
Old Jan 30, 2008 | 02:41 AM
colinwashere51's Avatar
colinwashere51
why two and a half?
treat the kid like hes yours its only fair
umm i would say go to an Lt1
theres more aftermarket there in the event you ever want more horsepower
Old Jan 30, 2008 | 08:08 AM
dclafleur's Avatar
dclafleur
Originally Posted by colinwashere51
why two and a half?
More aftermarket? Alright...
I say upgrade the heads, by the time you're done having them welded and then ported to get to the HP numbers you're looking at you'll be out the cost of a new set of performance heads anyways.
You aren't getting to 300 without a new set of heads on the car anyways.
Old Jan 30, 2008 | 09:27 AM
Slalom4me's Avatar
Slalom4me
300. What would be the cheapest way to get to 300hp. I figured that
wondering if i should just get it running or wait till I had some more
My vote is that repairing and rebuilding the existing heads will
cost more than replacing them.
For replacement there is OEM for a direct bolt-on solution (but little
if any improvement), and there is aftermarket (which almost always
entails additional work $$.)
One aftermarket option to consider is what Trick Flow now call their
Super 23 Street. There are several good heads on the market, the
advanage of these is that in addition to flowing considerably better
than the OEM heads, the TF have 54-56cc chamber sizes and are
essentially bolt-on replacements. I know of no other aftermarket Al
heads on the shelf with chambers this size.
For assembled heads, the product choices currently listed at TF's
site
are
Perimeter bolt
30300001 - 0.480 in.
30300002 - 0.540 in.
30300003 - 0.600 in.
Centerbolt
30300005 - 0.480 in.
30300006 - 0.540 in.
30300007 - 0.600 in.
Some tips about the part number nomenclature. TF identifies products
using the following scheme: ***AB**C (ie: 30300007). The alpha/numeric
values in positions A, B and C refer to:
A: casting qty - 0 & 2 means 'pair', 1 means 'each'
B: bare or assembled - 0 means assembled
c: max lift and v-cover bolt style
As always, do your own due diligence.
Old Jan 30, 2008 | 09:30 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you want 300 HP go ahead and do after market heads/cam now. Your 128 heads aren't that great anyway. Trying to salvage them makes no sense to me. You need to stay around 180-190 cc heads. Brodix or Edelbrock will cost less than others. Go ahead and install a cam with more lift while you are at it. With the proper combo you should pop over 300 CHP.
Edit: just had another thought. You can get bare ZZ4 heads for under $500 that will bolt right up. You can use GMPP valve train parts as well.
Old Jan 30, 2008 | 09:38 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I would just get the heads rewelded (if they can, sometimes...) Anyway it's going to take more than heads to get you there. You can be using the car until you decide what to do, and your old heads would then be worth about $400 to someone (They actually are quite sought after).
Old Jan 30, 2008 | 01:11 PM
bdaum2112's Avatar
bdaum2112
why two and a half?
I treat her like shes mine she treats me like im not that why the half.
Old Jan 31, 2008 | 03:27 AM
colinwashere51
thats totaly fair then
Old Jan 31, 2008 | 03:38 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Take a look at these:
http://store.summitracing.com/partde...part=EDL-60879
BTW, my vote is to buy the after market heads.
Old Jan 31, 2008 | 08:08 AM
rick lambert's Avatar
rick lambert
After market! don't waste your time on the old heads if 300hp is your goal.....I'd do the cam too while I had everthing apart.
Old Jan 31, 2008 | 04:13 PM
bdaum2112's Avatar
bdaum2112
I think i will go with after market heads and a new cam. The only issue now is should I rebuild the transmission while i got it a torn down and how do i do that is a gravel driveway in the middle of winter........ The wife won the big master bed room vs a garage when we purchased the house. Thanks for everyones input.
Old Jan 31, 2008 | 05:47 PM
Demonic85's Avatar
Demonic85
A good set of heads, cam, exhaust, and a tune. You will be more than pleased
To L98 Cracked Heads
