replacement injectors
Old Dec 1, 2001 | 04:16 PM
GlockLT4's Avatar
GlockLT4
Default replacement injectors
Ok, 45psi down to 0 psi after 2.5 hours. Time to replace an injector or two. I can replace only the ones I need to, right?
Anyone know the model # of the Ford's that we can use? Is it ok to mix Ford and Chevy?
Gracias
Old Dec 1, 2001 | 05:10 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: replacement injectors (Glock'94)
I don't have that info, but you could send the set to Rich at http://www.cruzinperformance.com/. He can recondition & flow test the set (for ~$80) and replace any that are needed. Plus he can blueprint the set.
Old Dec 1, 2001 | 05:54 PM
GlockLT4's Avatar
GlockLT4
Default Re: replacement injectors (65Z01)
Ah, that's right. Almost forgot about him... now if only my vette wasn't my daily driver :(
Old Dec 1, 2001 | 07:30 PM
olephart's Avatar
olephart
I believe the Ford injectors are rated at a different fuel pressure than the OEM's. You would have to do the math to see if they flow the same as the oem at the pressure you are using.
I kinda doubt they would match well enough to mix them in with the OEM's.
$80 seems like one heck of a deal. A full set of the fords are $200-240.
To replacement injectors
