87 Injectors - question
Old Dec 1, 2001 | 06:19 PM
Fla96LT4's Avatar
Fla96LT4
Default 87 Injectors - question
How do you remove the electrical connection to check the ohms? Is there a clamp or is it just a press fit? Thanks
Old Dec 1, 2001 | 06:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 87 Injectors - question (Fla87)
Locate the wire clip that is visible on either side of the harness connector. Press this clip in on each side with your thumb and forefinger and wiggle the connector as you pull it off the injector.
Old Dec 1, 2001 | 09:11 PM
Fla96LT4's Avatar
Fla96LT4
Thanks for the help!
To 87 Injectors - question
